AURALiC ALTAIR G1 Hi-Fi Streamer DAC 32bit 384Khz DSD512 AES/EBU Femtoclock Black
True high fidelity HUB, the Auralic ALTAIR G1 combines the functions of streamer, DAC, preamplifier. It delivers a breathtaking audio reproduction with flawless ergonomics.
By buying this product you get 239 loyalty points
Reference : 14060
2 399,00 €tax incl.
1 999,17 € tax excl.
AURALIC Altair G1
Streamer Roon Ready, DAC ES9038QM 384kHz / DSD512, Dual Femto, Preamplifier
True high fidelity HUD suitable for all high performance audio systems, ALTAIR G1 keeps all the hardware and software strength from its predecessor (ALTAIR first name). That is to say it provides - with remarkable accuracy - functions of network streamer / file player, DAC and preamplifier.
It has renewed ergonomics and design : ALTAIR G1 now comes with a stylish housing G1 type and a stunning 4-inch color screen.
Audio performance is also progressing with the integration of a chip DAC ESS 9038Q2M. A component that allows a return even more complete with a resolution and a detail level than its predecessors. Naturally, this update of the digital circuit is accompanied by a consolidation of the analog circuitry to operate in the better performance gain.
At last, the computing power jas been upgraded too with the introduction of the second version of TESLA processor (ARM Cortex A9 G2 4 cores) and 2GB of RAM for a most accurate listening experience and seamless track playing.
Digital HUB for High Fidelity sound installations
The Altair has multiple digital inputs (AES-EBU XLR, RCA SPDIF, USB, RJ45).
This stream is thus a true digital audio HUB thank to a DAC with very accurate digital volume control. Its calculation capabilities and the power of algorithms make it able to conveniently replace traditional configuration including preamp / power amp.
Ever increading audio accuraccy
The AURALiC Altair has all the technology including the digital filter "Precise Mode Filter" which unlike conventional filters (SHARP FAST and SLOW) has a natural rhythm capacity (little pre and post echoes) near NOS converters without their faults noise and resolution loss in the acute medium.
Coupled to the Femto double clocks Clocks (multiple of 44.1 kHz and 48kHz separated -151Hz very low phase noise) with a dedicated 9V, the AURALiC Altair is a tour de force combining High Resolution and melodic capacity unusual.
Contrôle IR intelligent
The Smart IR Control system allows you to automatically associate your Auralic Altair G1 player with any infrared remote control.
All you need to do is indicate to the device your preferred remote control and assign the functions: play / pause, volume, track selection, etc. buttons on the remote control.
Optimum ergonomics
The AURALiC Lightning DS application for iPhone and iPad is the most comfortable of the market with a fast response time and a clear interface to use. Open to the world, the AURALiC Altair has an entry in WiFi format for monitoring and high resolution wireless streaming. In addition, Altair has a 2.97 inchestype afiicheur more readable, without reflection.
Dimensions
Through integration G1 type frame, this version of ALTAIR is now perfectly matched with the rest of the range G1 of the same manufacturer.
Its dimensions and its form-factor allow an aesthetic and orderly organization of the entire high-fidelity system.
TypeStreamer
DAC
Volume control
Preamplifier
supported mediashared file (network)
USB key
Media Server UPnP / DLNA
TIDAL
Qobuz
WiMP
Internet radio
Spotify Connect
AirPlay
Bluetooth
Roon Ready
Supported File FormatsAAC
AIFF
ALAC
APE
DFF
DSF
FLAC
MP3
OGG
WAV
WV
WMA
Streaming platformAURALIC G2 Tesla General Computing
System memory2GB RAM
Storage memory4GB
Digital inputsEthernet (up to 384kHz - 32bit / DSD512)
USB (up to 384kHz - 32bit / DSD512)
Toslink (up to 192kHz - 24bit)
Coaxial (up to 192kHz - 24bit)
AES / EBU (up to 192kHz - 24bit)
Analog outputsunbalanced output (THD <0.0002% DNR> 124dB)
balanced output (THD <0.0003% DNR> 121dB)
Wireless ConnectivityWLAN 802.11b / g / n / ac Tri-Band
AirPlay
Bluetooth
Clockmaster clock FEMTO 72fs
Power supplyInternal circuit line feed
Design 10uV falble noise audio circuits
Displayhigh resolution screen 3.97 inches
Control SoftwareLightning DS (IOS 10 & up)
Android Apps OpenHome
Roon
Third party control software
Dimensions340 x 320 x 80mm
Weight6.8kg
InputS/PDIF
InputRJ45
DAC / ADC ChipES9038Q2M
Max sampling rateDSD512
Max sampling rate384kHz
Streaming services & Network protocolsQobuz
Streaming services & Network protocolsWeb radios
Streaming services & Network protocolsRoon / Roon Bridge / Roon Ready
Streaming services & Network protocolsTidal
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsSpotify Connect
On frôle ici la perfection !
Commandé un jeudi en milieu d'après-midi et reçu le samedi matin. Qui dit mieux ? Chapeau bas à l'équipe Audiophonics !
Superbe appareil magnifiquement assemblé. De l'emballage à lecteur lui-même en passant par l'application, tout respire la qualité. Cela faisait des années que j'étais à la recherche du lecteur parfait. Je n'en ai pas essayé beaucoup mais je crois bien désormais l'avoir trouvé ! Tout y est bien pensé et bien fait. Si vous avez le budget alors n'hésitez pas une seconde. Vous allez redécouvrir vos musiques préférées ! Le seul petit nuage dans ce ciel bleu azur est l'absence d'une entrée IR arrière qui m'aurait permis de l'intégrer à ma télécommande universelle. Pas de drame toutefois, la qualité est tellement au rendez-vous que ce petit détail est vite oublié !
Bonjour,
L’Altair G1 dispose de la fonction SmartIR (avec un capteur IR en façade) qui permet de programmer n’importe quelle télécommande du marché via le menu de configuration en façade.
This review has been posted for AURALiC ALTAIR G1 Hi-Fi Streamer DAC 32bit 384Khz DSD512 AES/EBU Femtoclock Black
True high fidelity HUB, the Auralic ALTAIR G1 combines the functions of streamer, DAC, preamplifier. It delivers a breathtaking audio reproduction...
