AURALiC Altair Hi-Fi Streamer DAC 32bit 384Khz AES/EBU Femtoclock Silver
By buying this product you get 199 loyalty points
Reference : 11057
1 999,00 €tax incl.
1 665,83 € tax excl.
he streamer audiophile L 'AURALiC Altairis a digital audio player featuring the quintessence of the brand's know-how in a sleek case less than 6.5cm high in aluminum ALLOY AFN 402.
The computing power is well beyond the specifications of modern Hifi with the integration of the famous processor Tesla ARM Cortex A9 four hearts(computing power 25.000MIPS) which have made the success of Streams AURALiC Aries and Aries Mini.
Fusion of the rigorous design of the converterVEGA AURALiCand Hifi streamers of the brand, here is the perfect tool for any seasoned amateur wishing high resolution and musical tracking in a single box.
The AURALiC Altair benefits from all the technologies of these elders and notably the digital filter " Precise Mode Filter"which, in contrast to conventional filters (SHARP, FAST and SLOW), has a natural rhythmic capacity (low pre and post-echo) close to NOS converters without their noise defects and loss of resolution in the acute medium.
Equipped with a DAC SABRE ES9018 32bit 384Khz
with 64bit digital volume, the AURALiC Altair preserves the dynamics of High Defintion files that fit perfectly into a modern Hi-Fi system.
The Altair has digital inputs (AES-EBU XLR, RCA SPDIF, USB2.0). This Streamer becomes a true DAC HUB digital audio for external sources with a very high level digital volume control replacing advantageously any aging analog preamplifier driving a power amplifier with XLR or RCA inputs.
Strokewith double clocksFemto Clocks(multiple of 44.1khz and 48khz separated with very low phase noise -151Hz) with a dedicated 9V power supply, the AURALiC Altair is a true tour de force marrying High Definition and unusual melodic capability.
TheapplicationAURALiC Lightning DSfor iPhone and iPad is among the most comfortable market with fast response time and a clear interface to use. Open to the world, the AURALiC Altair has a Wifi input for control and streaming in high-resolution wirelessly. Moreover, L'Altair has an Amoled-type display of the most readable, without reflection.
Press release 6Moons.com test bench of the Auralic Altair
Test By The Hans Beekhuyzen Channel
Specifications AURALiC ALTAIR:
  • Frequency response: 20 - 20KHz, +/- 0.1dB *
  • Total harmonic distortion: <0.001%, 20Hz-20KHz to 0dBFS.
  • Dynamic Range: 121dB, 20Hz-20KHz, Weighted A.
  • Output level in Volt: 4Vrms maximum on XLR.
  • Output level in Volt: 2Vrms maximum on RCA.
Network and Physical Inputs:
  • 1 network entries: network for shared folders: (NAS uPnP / DLNA Media Server)
  • 1 USB input pour hard drive 2.0.
  • 1 hard drive option 2.5-inch HDD or SSD installed (not supplied).
Compatible with wireless transmissions and streaming network:
  • TIDAL and QOBUZ.
  • Internet radio.
  • AirPlay.
  • Bluetooth.
  • SongCast.
  • RoonReady.
Digital Inputs:
  • 1x AES / EBU.
  • 1x Coaxial.
  • 1x Optical Toslink.
  • 1x USB control to computer.
  • 2x USB host for hard disk and DAC.
  • 1x RJ45 Gigabit Ethernet.
  • 1x 802.11b / g / n / ac Tri-Band WiFi.
Analog Outputs:
  • 1x Stereo balanced XLR (10ohm output impedance).
  • 1x Unbalanced RCA stereo (output impedance 50ohm).
  • 1x Headphone output on 6.35mm jack (5ohm output impedance).
Supported Digital File Types:
  • AAC, AIFF, ALAC, APE, DIFF, DSF, FLAC.
  • MP3, OGG, WAV, WV and WMA.
Resolution and sampling frequencies supported:
  • All PCM formats from 44.1KS / s to 384KS / s to 32Bit ***
  • DSD64, DSD128, DSD256 ***
* Tested by AURALiC in "filter mode precise" on all sampling frequencies of the Streamer ALTAIR converter.
** 32bit resolutions and 352.8KS / s and 384KS / s sampling frequencies are supported by the network input and USB 2.0 input.
*** 32bit resolution is supported only through network input and USB 2.0 input.
*** On standard 'DoP V1.1' where DSD native protocol and streaming network and USB input only.
Compatible control software and interfaces:
  • AURALiC Lightning DS for iOS.
  • Remote control: AURALiC RC-1.
  • OpenHome uPnP software compatible (Bubble uPnP, Banshee 2.4 and higher, Kinsky, Plex, Plug, VLC uPnP, Kodi.).
Power consumption:
  • Standby: <10W.
  • Reading: 35W max.
Dimension :
  • 33cm x 23cm x 6.5cm.
Weight :
  • 3.2kg.
InputWiFi
InputXLR
InputRJ45
OutputJack 6.35mm
DAC / ADC ChipES9018
Max sampling rateDSD256
Max sampling rate384kHz
ColorSilver
