SMSL DP3 Streamer DLNA Airplay Bluetooth aptX DAC 2x ES9018Q2C 32bit 384kHz DSD256
After having proposed their flagship, the FDA AD18, SMSL returns and completes its range with the DP3. We have here to do to a complete network player with many features and high performance.
4.3 / 5
Reference : 12815
299,00 €tax incl.
249,17 € tax excl.
SMSL DP3
DLNA Airplay Bluetooth Network Player aptX DAC 2x ES9018Q2C 32bit 384kHz DSD256
SMSL DP3 Network Reader
After having proposed their flagship, the FDA AD18, SMSL returns and completes its range with the DP3 . We have here to do to a complete network player with many features and high performance. A network drive that will perfectly match the AD18 to have a versatile system.
SMSL DP3 Network Drive features
Control your music from your smartphone
For a smooth and streamlined experience, SMSL combines with the application Hiby Music, a player for high resolution files. By downloading it, you can enjoy the HibyLink experience via bluetooth. This will allow you to control your device and play files on your USB media directly from your smartphone.
SMSL DP3 Smartphone control
New interface
With its IPS screen, the DP3 will allow you to easily access all the information concerning the reading of your files, and this via an ergonomic and aesthetic interface. An interface designed to offer a more fluid experience.
SMSL DP3 Interface
Your network music
The SMSL DP3 will allow you to access the contents of USB disks / USB flash drives / SD cards connected to them, and to control their playback from the built-in screen, or via the Hiby Music application ( bluetooth link)
It also acts as Bluetooth receiver APT-X, for sending an audio stream from a phone for example.
It can also connect to your local network, both Ethernet but also Wifi to read shared files on a NAS, or provide DLNA / Airplay receiver function.
In network the reader proposes several protocols:
  • DLNA protocol: Allows you to receive a DLNA stream through the network to read your files
  • AirPlay Protocol: Allows you to play your music directly from an Apple device
  • Samba Protocol: Allows you to play your music from a PC or NAS on your local network
*** Note on SAMBA: (classic network share)
The player is able to reach files on the network via the interface available on the screen in front, BUT it is not possible to control the reading of these files other than through this
SMSL DP3 DLNA Airplay LAN Network Player Airplay
Connectivity more than complete
In order to adapt to all needs and uses, the DP3 has a complete range of connectors.
It will be found in outputs of Optics Toslink, Coaxial, AES (XLR) and RCA.
In addition, we also find in front two headphone outputs Jack 6.35mm and XLR 4 poles, the latter corresponding to a balanced output.
In terms of inputs, the DP3 offers a micro-usb port for connecting it to a computer.
The USB ports allow to address an external DAC (With XMOS interface, Amanero, CM6631 ...) or to connect a key / USB hard disk.
There will also be a front port to read his music from a Micro SD card.
The DP3 volume knob also controls the level of the line output.
SMSL DP3 Connectivity
Bluetooth 4. &aptX
The network drive therefore offers Bluetooth 4.0 for fast data transfer. The integrated chip supports the aptX protocol, which allows to increase the transfer rate but especially to make it more stable for a better quality audio reproduction. The device can behave as both receiver and transmitter. In reception it will act like a reading interface, in emission it will act simply like a digital plate.
SMSL DP3 2x ES9018Q2C
A powerful DAC
The SMSL network reader is equipped with a double ES9018Q2C SABRE DAC from ESS. It provides a high-quality conversion that provides broad dynamic range, low distortion but also support high definition files up to 32bit in PCM and native DSD256. Of course, all popular formats are compatible with the device.
Connected in USB on a PC, you can use the DP3 as a classic DAC by reading files from your computer.
A precise reader
If the DP3 is adorned with a very good conversion chip, it also incorporates twoHigh precision clocks with very low phase noise, allowing the jitter to be lowered drastically. The heart of the device is a 22.579Mhz clock and a 24.576mHz clock. The jitter is thus lowered to 0.1ps @ 10Hz-1Mhz and the phase noise is below 166dBc / Hz @ 1Mhz. This design allows the device to maintain a high-precision signal for accurate reproduction.
SMSL DP3 double clock
Télécommande SMSL
Remote control provided
The DP3 is supplied with its remote control.
The latter allows to control the SMSL DP3 without leaving the couch. Whether reading or navigating the menu (source selection, DSD reading type ... etc.)
It also has a programmable button that can be assigned to the command of his choice according to the specificities of his audio installation.
SMSL DP3 Dimensions
Qobuzissime for the SMSL DP3
" The S.M.S.L DP3 is a device that you can quickly take advantage of, in particular, with a small adaptation, with the HiBy Link and you can only be pleased with its decoding capabilities and excellent sound performance. "
Test SMSL DP3 par Qobuz
b "> Technical characteristics
DAC2x SABRE ES9018Q2C
THD + NLine out: 0.0008%
Asymmetric output: 0.0008%
Symmetrical output: 0.0004%
Dynamic rangeLine out: 121dB
SNRLine out: 112dB
Asymmetric output: 112dB
Symmetrical output: 110dB
Power headphone outputAsymmetric output: 58mW @ 32Ω / 46mW @ 64Ω / 26mW @ 150Ω
Balanced output: 113mW @ 32Ω / 110mW @ 64Ω / 78mW @ 150Ω / 49mW @ 300Ω
Line output level2Vrms
USB sampling ratePCM up to 384kHz
DSD256
USB CompatibilityWindows 7, 8, 8.1, 10 / Mac OS X / Linux
File systemFAT, FAT32, NTFS
Max capacity Micro SD (not included)256GB
Max capacity USB stick / Hard disk (not included)4TB
Bluetooth type4.0 aptX
Remote controlYes / Remote control included
Connections: Inputs
Ethernet (RJ45)1x
Micro-USB1x
Micro SD1x
Bluetooth 4.0-
DLNA-
Samba (NAS)-
Connections: Outputs
RCA Stereo1x
Toslink optics1x  (no volume control)
Coaxial1x (no volume control)
AES (XLR)1x (no volume control)
USB-A2x
Jack 6.35mm (Headphones)1x
XLR 4 poles (Headphones)1x
ConsumptionIn operation: 3W
Standby: 0.5W
dimensions215 x 238 x 45mm
SMSL DP3 sampling rate
Input
  • Bluetooth
  • Micro SD
  • RJ45
Output
  • Coaxial SPDIF
  • Jack 6.35mm
  • Optical Toslink
  • RCA
  • XLR
Color
  • Black
DAC / ADC Chip
  • ES9018Q2C
Max sampling rate
  • 384kHz
  • DSD256
6 reviews
très bon produit.Excellent couplé avec un smsl sanscrit.
et ampli classe d.
Sonorité transparente.
This review has been posted for SMSL DP3 Streamer DLNA Airplay Bluetooth aptX DAC 2x ES9018Q2C 32bit 384kHz DSD256
super appareil complet et de qualité à petit prix
J'utilise le dp3 uniquement en lecteur de fichiers stockés sur un disque dur branché au port usb de l'appareil.
Aussi bien avec la télécommande et le petit écran, ou bien avec l’application Hiby sur mon smartphone, qui me donne accès aux dossiers contenus dans le disque dur.
Simple et efficace.
Concernant le dac intégré, il est vraiment pas mal, très détaillé, beaucoup de relief, scène large mais j'utilise malgré tout mon dac externe Musical Fidelity v-dac2 qui offre un petit plus niveau réalisme et naturel.
La section ampli casque est vraiment bonne aussi, sans atteindre le niveau d'immersion et de sensualité de mon ensemble v-dac2 + ampli bravo audio mk1 à tube .
Excellent rapport qualité prix
Ce streamer véritable couteau Suisse est une très bonne affaire a ce tarif, il est "presque" résolument hifi, en clair excellent pour une écoute de très haute qualité et il est dommage qu'il soit entachés de bugs qui sont difficile à résoudre. De plus le firmware fourni par smsl ne rend pas justice à l'appareil un groupe de passionnés Russe ont réussi a faire une rétro ingénieries sur le firmware et ont supprimé une particularité de l'original qui consistait à réinjecter sur canal gauche le signal inversé du canal droit et affaibli de 18db c'est une astuce qui permet d'obtenir a l'écoute une image plus large et plus profonde mais au détriment de la signature réelle de ce Dp3 qui en devient presque brouillon.
Si vous cherchez ce firmware sur Gogol cherchez à Pogoo + forum des indépendants. Je ne sais pas si Audiophonics laissera passer cette info mais si oui sachez que ce lecteur excellent en deviendra fantastique.
Par contre désolé j'ai pas testé le Dac et je ne le ferai peut être pas.
Musicalement
tout simplement génial
Je ne l'ai testé qu'en lecture de carte, clé USB et DD externe en le branchant sur un SMSL A 8 en SPDif coaxial, en lui mettant un câble d'alimentation secteur de grande qualité; c'est bien simple, je n'ai jamais entendu quelque chose de pareil; c'est d'autant plus incompréhensible pour moi que je n'utilise pas son DAC , j'utilise celui du A 8, il ne sert donc en principe qu'à lire la bibliothèque de fichiers WAV et FLAC ! c'est sublime, et pour le prix, ahurissant ! et comme je suis plutôt du genre à m'asseoir pour écouter la musique que j'aime, plutôt qu'à vouloir de la musique de fond dans toutes les pièces de la maison que je peux changer à la volée quand je veux, je considère que cet appareil comblera de bonheur le plus exigeant des audiophiles, tous prix confondus...je précise que je viens d'un système de lecture sur ordinateur extrêmement performant qui du coup va se retrouver dans ma salle de cinéma :-D
Un dernier point: je remercie toute l'équipe d'Audiophonics pour son professionnalisme, sa réactivité et son soutien; un exemple qu'on aimerait rencontrer plus souvent.
Son exceptionnel en DLNA avec dac externe
Ce petit boitier bien construit procure un rendu sonore à un DAC connecté en USB ou coaxial absolument bluffant : grande profondeur et largeur de scène, début et fin de notes saisissants, à ce prix je me demande quel est son concurrent.
Seul bémol : le firmware est mal programmé, il fonctionne de façon capricieuse en dlna et reste très instable avec un dac connecté en USB.
Utilisé comme lecteur de fichier local c'est une affaire, le rendu dépasse largement une Digione, d'après mes essais et d'autres retours sur les forums audio.
After having proposed their flagship, the FDA AD18, SMSL returns and completes its range with the DP3. We have here to do to a complete network...
