I had a problem with my setup as I was very newbie in electronics, I lost the screen display and remote control, but the volumio works and the sound is excellent and now I am waiting for help from the technical team with my problem
This RaspDAC Mini Pi 4 has been replaced by its new version, available here : AUDIOPHONICS RASPDAC MINI LCD Kit DIY
Caution: To work, this kit needs to be combined with a Raspberry Pi 4 and a power supply sold separately.
This kit is only compatible with Raspberry Pi 4
Kit Network Player & DAC 32bit 384kHz / DSD 128
Enjoy the features and the finesse of a RaspDac with this kit designed to be assembled by hand.
Ideal to improve your sound system while having fun, this kit is a very intuitive opportunity to learn the basics of audio-oriented DIY method.
The assembly involves neither welding nor special knowledge in DIY. The only tools required are a H5 hex screwdriver and a P4 Phillips screwdriver.
Once mounted, the whole device constitutes a network drive based on Raspberry PI, with all the advantages that it represents in terms of connectivity.
The digital / analog decoding is done internally by a dedicated DAC ES9038Q2M chip, one of the best component in the field of high-fidelity music. This compact model can compete with devices that are way more impressive from their size or their price.
All decoding operations are made thanks to an I-sabre card ES9038Q2M. The latter was specially developed to make the best of a SBC (Raspberry Pi).
This DAC works with its own power stage with DC DC converter and integrated linear regulators. It incorporates the latest optimizations (2020) including an anti-pop relay.
When operated in conjunction with a software solution that has an optimized audio kernel (as is it the case here), the RPI and DAC I-sabre are able to play 32bit 384kHz.
DSD files are also supported up DSD128 (DOP).
The analog output stage is based on two bipolar operational amplifiers NJM 2114 fed with 9V. A third OPA of the same type serves as a buffer. This configuration ensures optimal resolution and a very stable output signal.
"The AUDIOPHONICS DAC I-Sabre ES9038Q2M finally brings good performance to HAT DACs. It rivals the performance of the higher priced DACs from Allo and Orchard Audio but at lower cost."
The ES9038Q2M DAC chip offers hardware volume control function (does not damage audio resolution). This hardware volume is controlled remotely from the user interface (smartphone, tablet ....) for maximum comfort and optimal accessibility in any circumstance.
Similarly, playback options and source selection are made on smartphone / tablet (or any other connected device capable of running a web-browser).
Thanks to its software, the RaspDac mini can stream music from DLNA / AIRPLAY compatible devices.
Finally, an infrared remote control also offers access to the basic functions.
By combining the ports of a Raspberry Pi with those of the ES9038 sabre card, the device now offers an impressive connectivity.
The Raspdac Mini has 4 USB-A ports to which the user can plug a hard disk, a USB drive or even a USB CD drive.
Of course, the device is also perfectly at-ease when it comes to play online hosted files through a wired network (RJ45) and non-wired (Wifi / Bluetooth).
The Mini RASPDAC simplifies your audio setup with an extra S / PDIF input port that can connect an extra digital source (CD player, television, gaming platform ... etc). It can thus be effectively integrated in various cases with sufficient flexibility to make all your digital devices enjoy the RaspDac efficiency.
Its dimensions of 60 x 90 x 120 mm allow the RaspDAC Mini to fit easily into your audio environment, regardless of size and complexity.
All ports are on the back of the case so as not to damage the visual harmony of your audio-system with visible cables.
Once your RaspDAC is installed and operational, it is not necessary for its operation to redefine wiring or to access the micro SD card. All of its functions can be set wirelessly.
RaspDac Mini is now capable to handle multiple audio-dedicated software solutions such as Volumio and moOde Audio.
Please note that no software are provided with the kit. You have to pick one from the list below :
You can get a micro-SD card with a ready-to-use moOde image we edited specifically for RaspDac Mini here.
We made this custom solution to make the process as easy as possible : just insert the SD card in your RaspDac Mini, turn the device on and follow the network configuration. Your RdM is ready to use.
This software solution is suited for user that want to be able to manage more complex integration process in the future. However it might not be the easiest solution to set up for utter beginners.
You can get a micro-SD card with a ready-to-use Volumio image we edited specifically for RaspDac Mini here.
Again, the process is really simple, just insert the SD card in your RaspDac Mini, turn the device on and follow the network configuration. Your RdM is ready to use.
If you have no experience with any audio-dedicated software or if you have no idea which solution is the best for you, you will find this one easy to set up and to use.
You already have an unused micro-SD (8GB of memory needed) and you are not afraid of doing the installation yourself. Every software image for the RdM is available for free on this webpage for a DIY installation. You can manage a DietPi installation this way as well.
DIY images installer are available for free without time limitations.
The front panel display will delight fans of sober aesthetic. The screen is indeed protected by a semi-opaque black acrylic surface, making it invisible when the unit is not powered.
When the mini RaspDAC is active, the screen displays all the information needed to identify the music (track name / album / artist / reading time), playlist (track number).
The screen also displays advanced information that will quickly confirm that the installation works as expected : sampling rate, source ...
CAUTION: TO WORK, THIS KIT NEEDS TO BE COMBINED WITH A RASPBERRY PI and a power supply SOLD SEPARATELY.
" This RaspDAC Mini Audiophonics streamer deserves to be played with the screwdriver to put it in the case because these efforts will be rewarded with high quality sound reproduction. "
Qobuz - Philippe Daussin
inputs | 4x USB 2.0-A 1x Coaxial 1x RJ45 1x Micro SD |
Exits | X1 RCA Stereo |
Supported audio formats | Up to 32bit 384kHz DSD (DOP) 128 |
dynamic range | 129dB |
THD + N | -120dB |
Power supply | USB-C (5V) |
Dimensions | Height: 60mm Width: 90mm Depth: 120mm |
Weight | 470g |
housing material | 100% Aluminum |
Color | Black |
Acrylic plate | x2 |
Acrylic Support | x1 |
Aluminum housing | x2 |
1.54 inch OLED Screen (White) | x1 |
Screen PCB | x1 |
I-sabre ES9038 DAC with matching PCB | x1 |
Infrared remote control (No battery) | x1 |
Expansion slot for Female Micro SD | x1 |
Spacers M2.5 - 20mm | x2 |
Spacers M2.5 - 10mm | x2 |
Phillips screw M2.5 - 15.8mm | x2 |
Phillips screw M2.5 - 8.1mm | x2 |
Phillips screw M3 - 7mm | x2 |
Allen screw M3 - 13mm | x8 |
Acrylic Nut M2.5 | x2 |
Bracket M3 | x2 |
Washer M3 | x2 |
RCA Washer Black / Red / White | x3 |
RCA Bolt | x3 |
Rubber stands | x4 |
USB-A to USB-C cable with switch | x1 |
Input | SPDIF |
Input | USB |
Input | Micro SD |
Output | RCA |
DAC / ADC Chip | ES9038Q2M |
Max sampling rate | 384kHz |
Max sampling rate | DSD128 |
Color | Black |
Average votes 4.6 / 5 9 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Sedat B.
Emmanuel C.
Jean C.
Zoran G.
Thibaut F.
