RaspDIGI LTE DigiOne digital network player Raspberry Pi & SPDIF
A high quality network player based on Raspberry Pi 3 B+ and the Allo DigiOne audio interface. Great performance, low for high definition digital and performance that adapts to your listening.
Reference : 12643
249,00 €tax incl.
207,50 € tax excl.
RaspDigi LTE, network player with digital interface
Rasp Digi LTE, lecteur réseau Raspberry PI
This sober and robust aluminum case combines the computing power of a Raspberry Pi 3 B+ motherboard with a high definition Allo DigiOne digital interface. This configuration forms a high quality network digital reader, with intuitive use and many connection possibilities. It also has all Raspberry 3 B+ wireless connections and will therefore be ideally controlled using a smartphone, a tablet or a computer via the network.
The RaspDigi LTE is a powerful network player optimized for high audio resolutions.
It only needs one software solution to be fully operational. Many open source software is available and everyone can choose the one that best suits their audio projects
Moreover, the installation and the change of software is done with ease thanks to an access to the Micro-SD card located at the back of the case and requiring no disassembly.
Most of the settings and operations being done directly by the network, the interface of the housing is extremely simplified and is limited to a single button on / off elegantly backlit
DigiOne by Allo
The RaspDIGI integrates the Allo DigiOne card. This digital interface is recognized as one of the best value for money in the current market. It uses only top quality components and its construction is designed to make the most of a Raspberry Pi based circuit.
His audio performance is remarkable, starting with his very low jitter rate of only 0.6ps. The DigiOne has a meticulous construction that makes 10 LDO regulators, 12 LPF filters, low-noise DC: DC converters, galvanic isolation and low drift oscillators work together. The interface ensures a very complete digital processing that rivals easily with the most high-end devices on the market.
The DigiOne allows the RaspDigi to work with sample rates up to 24bit 192kHz. It is also possible to exit the DSD / DXD via USB 2.0 ports. This player has all the essential elements for high quality audio. This is a very solid base for starting a new audio installation or for improving an installation lacking a high performance network player for high fidelity.
All these strengths make RaspDIGI an audio source of choice for a high fidelity installation.
Ready for numerical audio
Sorties RaspDigi Raspberry Pi DigiOne ALLO
In addition to its digital output, the RaspDigi LTE also takes advantage of all the basic conections available on Raspberry Pi. This means that this player has a very complete arsenal to transmit digital audio signal:  Coaxial / BNC and even HDMI and USB-A
It's quite possible to use it as both a network audio player and a video player based on the HDMI output without having to change the connections.
Although they share the same power supply, the circuits of the digital interface and the motherboard are isolated. This makes it possible to limit the number of cables in more complex installations while benefiting from equally high quality digital processing.
All these options will allow multiple simultaneous connections and give priority to an output depending on the DAC used.
Want to use PicorePlayer instead? You can by visiting this link.
MotherboardRaspberry Pi 3 B+
Digital interfaceAllo Digione
Input4x USB-A / RJ45
OutputBNC / RCA Coaxial
Régulators10x LDO
Filterts12x LPF
Converter DC/DC
Isolateur Galvanique Digital
Puce WM8805
Buffers
Oscillateurs NDK
Performances
Jitter 0.6ps
NOise level50uV
Dimensions
Depth (connectic included)187.4 mm
Depth ( housing alone)165 mm
Height :40 mm
Width :100 mm
Weight612 g
Alimentation
Alimentation100-240V / 5V 3A DC
Jack DC 5.5/2.1mm
Jack / Micro-USB
Mémoire
StockageCarte Micro SD Haute performance 8GB
Accessoires fournis
x1Carte micro SD HD 8GB
x1Adatateur secteur alimentation ALLO
x1Adaptateur jack / micro -USB
x1Adaptateur prise EU
x1Adaptateur prise UK
x1Adaptateur prise US
InputRJ45
InputMicro SD
OutputBNC
DAC / ADC ChipNC
Max sampling rate192kHz
ColorSilver
Streaming services & Network protocolsTidal
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsSpotify Connect
Streaming services & Network protocolsQobuz
Streaming services & Network protocolsWeb radios
Streaming services & Network protocolsTidal Connect
2 reviews
Lecteur sous Volumio
J’utilisais déjà Volumio sur un Raspberry dans un petit boîtier maison mais pas très esthétique.
J’ai donc commandé ce lecteur réseau (reçu sous 48 heures et très bien emballé, mais c’est de toutes façons à chaque fois pareil) et dès le déballage le boîtier est très esthétique, avec cette sensation de solidité.
Une fois branché, j’avoue que j’ai été très étonné du bon en avant en ce qui concerne les écoutes.
Je pense que la carte Allo Digione y est pour beaucoup.
Je trouve ça beaucoup plus aéré et précis.
Il est alimenté par une alimentation Audiophonics installé dans le même type de boîtier ce qui en fait un ensemble très agréable.
Merci à Audiophonics pour tous ces services de qualité.
Pascal
This review has been posted for RaspDIGI LTE DigiOne digital network player Raspberry Pi & SPDIF
Avis Raspdigi LTE
Bonne construction, solide, la finition est appréciable.
La carte Allodigione est agréable à l'écoute.
Je voulais signaler un problème avec la nappe d'extension de la carte SD. Celle-ci génère des i/o errors sur le file system.
J'ai testé en flashant 4 SD cards différentes (sandisk, intenso fournie) avec les systèmes Volumio, Moode, RuneAudio, M2P, Libreelec, à chaque fois des I/O errors survenaient tôt ou tard.
Plus aucun problème en branchant directement la SD card sur le slot du Raspberry.
Peut-être un problème d'interférences sur la nappe, je ne sais pas.
Mis à part ce souci qui m'a pris du temps je suis satisfait du produit.
A high quality network player based on Raspberry Pi 3 B+ and the Allo DigiOne audio interface. Great performance, low for high definition digital...
