RASPTOUCH I-SABRE V4 Audio Streamer with Touchscreen Raspberry Pi 4 & DAC ES9023 Black
With the RaspTouch, Audiophonics offers a simple and efficient hardware solution that combines both network drive and DAC. The device offers high quality audio quality through digital-to-analog analog conversion based on an I-Sabre ES9023 V4 DAC.
By buying this product you get 39 loyalty points
Reference : 11254
399,00 €tax incl.
332,50 € tax excl.
Audiophonics Rasptouch ES9023
Audiophonics RaspTouch ES9023 Lecteur réseau tactile Raspberry Pi 3B+ DAC I-Sabre V4 ES9023 TCXO Noir
The Concept
The Rasptouch allows you to enjoy your favorite music while controlling playback from its 7" touch screen, your smartphone or even your PC. The circuit dedicated to audio file playback works with a Raspberry Pi 4 SBC (Single Board Computer), making Rasptouch a versatile and particularly Open Source solution.
In short, Rasptouch is the combination of cleverly designed ergonomics, versatility and sound performance that ensures high fidelity listening.
Free to choose your operating system
RASPTOUCH I-SABRE ES9038Q2M KALI Lecteur Réseau Tactile Contrôleur de Volume
Advertising itself as an Open Source system, RaspTouch is delivered without an operating system. This choice will depend on your equipment, the ambition of your project and the expected functionalities.
The device is electronically ready for use. All that remains is to choose an operating system and mount it on a Micro SD card (sold separately). Many software solutions exist to meet all your expectations: Volumio, piCorePlayer, MoOde Audio, Max2Play, Roon...
Depending on the software chosen, you will be able to access the following features:
  • Full and unlimited multiroom support
  • Remote playback of audio files stored on a network-connected media server (NAS)
  • Remote reading from UPnP source
  • Reading from a USB source (hard disk, USB stick)
  • DLNA protocol management
  • Qobuz support
  • AirPlay support
Service d'installation du Système d'Exploitation VOLUMIO sur Carte Micro SD 8Go
This guide presents some compatible software solutions and their particularities : Start-up RaspTouch - RaspDAC - RaspDAC Mini with a pre-configured image..
The DAC
Based on an ESS ES9023 DAC ESS integrating the HyperStream architecture and capable of converting sampling rates up to 24bit 192kHz, the RaspTouch offers very good sound performance. The DAC ES9023 benefits from advanced technologies and a careful design allowing it to display excellent measurements such as a dynamic range of 112dB. Its high-precision TCXO 0.5ppm clocks and patented Jitter reduction technology ensure a particularly low jitter level.
Connectivity
The RaspTouch I-sabre 9023 V4 offers a simple and efficient connection system that will allow you to fully enjoy your audio system. Thus, we find the connectivity of the Raspberry Pi 4 with 4 USB-A 2.0 ports, a Micro SD port, an Ethernet port and a remote HDMI output. The analog audio output is done on RCA Stereo.
The RaspTouch comes with its power supply, plugging into the 5.5/2.1mm DC jack connector on the back of the unit. The power button on the side allows you to turn off the unit cleanly by turning off the system before turning off the power.
Warning, despite the Raspberry Pi 4 native Wifi connectivity, it has been sacrificed to install the player in an aluminum housing isolated from disturbances. The wifi connection requires an external adapter on USB (Wifi Dongle)....
Product typeStreamer
Inputs4x USB-A
1x Micro SD slot
1x RJ45
1x Stereo RCA
1x HDMI
2x 12VDC 1.25A
Raspberry Pi 4-
DAC ModuleAudiophonics I-Sabre V4 ES9023TCXO
ScreenTactile 7"
Official Raspberry Pi screen
Supported sampling ratePCM up to 24bit 192kHz
Dynamic range112dB
Power supply6V 3A via Jack DC 5.5/2.1mm (power supply)
Housing materialAluminium
Dimensions200 x 95 x 230mm
Rear dimensions175 x 55mm
Weight0.9kg
InputMicro SD
InputRJ45
OutputHDMI
DAC / ADC ChipES9023
Max sampling rate192kHz
Streaming services & Network protocolsSpotify
Streaming services & Network protocolsTidal
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsSpotify Connect
Streaming services & Network protocolsQobuz
Streaming services & Network protocolsWeb radios
Streaming services & Network protocolsTidal Connect
Very good hardware, sound really excellent - software NaJa not so good
Wanted a small audio streamer with a display.
I noticed this one and it looked very good.
From a build point of view it is very good. All I wanted.
Managed to get it up and running with Volumio - including the touch screen - very nice - sound very good.
So I would have rated it with 5 stars for my purpose and use case if if was not for the software. I am not a developer or hacker and besides it is hard to key in command line commands when using the browser UI.
I will keep it but will have to look for a better software.
I tried to get software up and running, what a major pain in the a..
I managed to get Max2Play up and running but was unable to mount my Synology NAS. Just didn't want to mount... so I actually but unusable (for my scenario) hardware. I could play music from a USB stick
Then tried out Volumio, where I managed to install the Raspberry 7" display driver. and voila on first try I was able to mount, I cannot see any difference in the commands between Max2Play and Volumio only that Volumio requires less information.
With Max2Play I couldn't get Wireless up and running.
With Volumio I can only make it work with wireless.
if I attach a ethernet cable I somehow get two entries for Volumio with two different IP adresses (but same MAC adress).
Hi,
Please give a try to Picoreplayer.
It's by far the greatest software solution for this device :
http://forum.audiophonics.fr/viewtopic.php?f=12&t=1756
Best regards
This review has been posted for RASPTOUCH I-SABRE V4 Audio Streamer with Touchscreen Raspberry Pi 4 & DAC ES9023 Black
With the RaspTouch, Audiophonics offers a simple and efficient hardware solution that combines both network drive and DAC. The device offers high...
