DSD1024 Player 768k PCM / I2S output with 32bit
Equipped with a 4 core processor 1.3G and an FPGA circuit (high speed audio algorithm), the S5 enjoys a formidable computing power.
This architecture dual core gives the reading abilities of camera and sound decoding; ideal for achieving high levels of accuracy and make out distinctly the sound details.
The FPGA operates two femtosecond clocks ultra low jitter, thus increasing the overall intelligibility of all shades.
In this photo, the S5 in Aune is connected to a DAC Asterion strap (not included) via I2S through HDMI. Such association allows to benefit from a digital stream of exceptionally fine, especially with the formats of the most demanding sound files.
Deliberately designed to integrate the most advanced sound installations, the S5 at Aune has a native I2S output. The entire chain and benefit of an optimum signal for the entire sound reproduction. This feature makes the S5 a particularly interesting player when it comes to potentiate the sound qualities of an effective DAC to maximize the capacity of its system.
Besides its kind I2S, digital audio player Aune also loads an optical output, coaxial and AES port. All these connectivity elements that promote easy and respectful integration of constraints so that the strengths of each element of the chain.
Besides the possibility to connect an external hard drive, USB drive or MicroSD card, especially the S5 has a mSATA slot. It may well have its own storage space and operate in total autonomy provided to install such equipment there.
His power brings great precision thanks to a transformer specially adapted to the constraints of such a digital circuit, two independent power supply as well as several secondary controllers with ultra-low voltage. The logical processors and doors involved in reading and enjoy a stable and reliable supply from the perspective of audio quality.
By connecting a USB CD drive to S5, the latter can directly retrieve the audio stream and function as an interface for high-fidelity playback, effectively linking the player to the rest of the string while applying its own computing power.
Aune offers a control application for Smartphone iOS. This is available in the "Download" tab of this page.
Type | digital music player |
Jitter @ 24bit / 44.1k | 204.5ps |
File rate support | |
Version | S5 (no DAC) |
HDMI-I2S | 768k / 32bit DSD1024 |
DSD | DSD64 / 128/256/512/1024 |
EPA | 192kHz / 24bit |
FLAC | 384kHz / 32bit |
wav | 768kHz / 32bit |
MP3 / WMA / AAC / ALAC / AIFF / CUE | full support |
Dimensions | 211 x 288 x 63mm |
Weight | 2.5kg |
Color | Black |
Package content | |
1x | S5 Digital music player |
1x | Power Cable |
1x | Remote control |
1x | WiFi antenna |
1x | USB stick (manual) 2GB |
Input | RJ45 |
Output | XLR |
Output | I2S LVDS via HDMI |
Output | Coaxial SPDIF |
Output | Optical Toslink |
Max sampling rate | 768kHz |
Color | Black |
