iEAST AUDIOCAST M5 Audio Receiver Wifi Multiroom DLNA Airplay
The iEast Audiocast M5 is a Wi-Fi audio receiver that supports simple and affordable DLNA, Airplay and UPnP protocols. It will also allow you to design a multi-room set with multiple iEast devices, via its iEast Play application.
4.8 / 5
Reference : 12723
31,90 €tax incl.
26,58 € tax excl.
Shipping date: 22-04-2025.
iEast Audiocast M5
Wifi Streamer Multiroom DLNA Airplay UPnP
Récepteur audio wifi iEast Audiocast M5
A simple and effective audio receiver
iEast offers with the Audiocast M5 an efficient and affordable solution allowing simple and unlimited streaming in all rooms of the house. Supporting DLNA, AirPlay and UPnP protocols, it can be associated with all compatible sources, such as a smartphone, a NAS (Synology, Qnap, ...) or a streaming service. The Audiocast M5 is also multiroom compatible and can interface with home automation systems for intelligent and optimized use.
In addition, to make the experience more fluid, the device embeds WPS technology for a quick association with your Wifi network. So you can enjoy your music in seconds, without any special configuration.
iEast audiocast m5
Streaming, home automation and iEast Play
The Audiocast M5 is compatible with many music streaming and web radio services. Examples include Spotify, Deezer, Youtube, iTunes, Google Play Music or Tunein.
Want to get even more out of your system? No problem, this one, like all iEast products has an API that will allow it to be controlled by third party applications or home automation controllers. For example, Fibaro offers a plugin that allows you to control your iEast devices directly from the Fibaro controller.
iEast also offers an application iEast Play available under Android and iOS to control your brand products remotely, access your music and manage multiroom broadcasting.
An accessible multiroom solution
Multiroom functionality allows you to synchronize your iEast devices with each other to play the same music on all your iEast players. This synchronizes the playout and you won't notice any lag when you change rooms. Via the iEast Play application it is possible to create multiroom groups to act on the broadcast in each room.
iEast Audiocast M5 multiroom
WifiIEE 802.11 b/g/n
Wifi Frequency2.4Ghz (150mbps max)
Sampling rateUp to 16bit 48kHz (DLNA / UPnP)
Dynamic range84dB
THD+N-85dB
Audio formatsLossless audio APE
FLAC
WAV
Apple Lossless (ALAC)
MP3
Powwer supplyDC 5V 1000mA (via Micro USB)
ConnectorsWifi Antenna (included)
AUX Jack 3.5mm Input
Dimensions5.5 x 5.5 x 1.7cm
Weight120g
PackageiEast Audiocast M5
Micro USB Cable
Jack 3.5mm to Jack 3.5mm cable
User manual
Firmware 4.2.7706.0Deezer support
Amazon Music support (US region only)
Add direct streaming on app
Stability and reliability optimisation
InputWiFi
OutputJack 3.5mm
DAC / ADC ChipNC
Max sampling rate48kHz
Streaming services & Network protocolsSpotify
Streaming services & Network protocolsQobuz
Streaming services & Network protocolsWeb radios
Streaming services & Network protocolsDeezer
Streaming services & Network protocolsTidal
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsSpotify Connect
4 reviews
Audiocast m5
Petit boîtier qui a fini par être reconnu par l’application après plusieurs essais. La mise en service est un peu fastidieuse mais le résultat est tout à fait convainquant. Intègrė à un ensemble Dayens Menuetto et Triangle comètes cela fonctionne très bien avec une bonne qualité rendu. Je l’ai associé à un petit ampli Project afin que le volume d’entrée soit convenable sinon le volume de l’ipad doit être poussé au maximum pour rester dans la tranche de classe À de l.ampli. Outre la mise en route il y a de la latence lors de la lecture des clips vidéo et l’EQ se remet sur « null » à chaque redémarrage.
This review has been posted for iEAST AUDIOCAST M5 Audio Receiver Wifi Multiroom DLNA Airplay
pratique pour relier au reste du réseau
Déjà détenteur de plusieurs Audiocats, j'ai renouvelé l'achat car je m'en sers pour mettre tous les équipements non DLNA dans mon réseau musique multiroom basé sur un serveur LMS (Logitech) hébergé sur mon NAS. Le boitier AudioCast permet fort bien de transformer en enceinte connectée DLNA tout appareil pourvu d'une sortie audio.
Pour l'installation en effet on peut passer par le WPS mais dans mon cas il m'a suffit fort simplement de connecter ma tablette au Wifi (hotspot) de l'audiocats pour ensuite indiquer la clé Wifi et laisser l'application tout faire. A noter que pour l'upgrade Firmware, on est guidé et que l'audiocast vocalise (en anglais) les étapes ce qui est rudement pratique pour éviter le trou durant les 2 ou 3 mn de la mise à jour (il y a de mémoire 3 messages vocaux confirmant que ca avance bien). Bref pour le prix c'est très pratique et me permet d'envoyer de la musique ou histoires pour les enfants n'importe où.
Petit boitier
Je l'utilise pour rendre une enceinte Muse connecté au réseau, afin de mettre des histoire à ma fille. Ca fonctionne parfaitement. Le boitier est visible sur BubbleUpnp , spotify (et d'autres que je n'ai pas testé).
Attention au premier paramétrage. bien lire la notice, pour l'associer au réseau WIFI il faut appuyer sur le bouton WPS, ceci afin que le logiciel Audicast le reconnaisse et que l'on puisse le paramétrer.
Ce M5 fonctionne comme borne WIFI avec son propre réseau, ce qui peut être pratique si vous perdez le réseau principale. Ce n'est pas du gros débit, environ 2-3 mbits.
audiocast M5
bonjour, produit expedié rapidement, conforme à mon utilisation à savoir lire ma musique en airplay sur mon ampli, appareillage pas evident au premier coup sur ma livebox , aussi après maintes essais fonctionne plutot bien, je l'utilise surtout pour envoyer mes musiques depuis disque dur branché sur livebox play depuis application music streamer et la c'est que du plaisir, tous les formats sont reconnus, ras, par contre via application ieast play je ne peux avoir accès à mes fichiers sur mon serveur livebox malgré le fait qu'il soit reconnu mais n'affiche rien du tout, pourquoi je n'ai pas encore trouvé la solution mais si quelqu'un pouvait m'aider ça serait avec plaisir, voilà mes ressentis sur le produit, pour le prix je le recommande sans detour sur ce site, allez y.
The iEast Audiocast M5 is a Wi-Fi audio receiver that supports simple and affordable DLNA, Airplay and UPnP protocols. It will also allow you to...
