MATRIX ELEMENT X Streamer DAC ES9038PRO XMOS WiFi Femtoclock 32bit 768kHz DSD1024
Matrix presents the Element X, a high-end network drive that is versatile, powerful and aesthetically pleasing. It opens the doors of high-fidelity music streaming and integrates cutting-edge technologies that enable it to support high-resolution files or even to ensure sound reproduction of astonishing richness, precision and depth.
By buying this product you get 331 loyalty points
Reference : 13408
3 319,00 €tax incl.
2 765,83 € tax excl.
Matrix Element X
Matrix presents the Element X, a high-end network drive that is versatile, powerful and aesthetically pleasing. It opens the doors of high-fidelity music streaming and integrates cutting-edge technologies that enable it to support high-resolution files or even to ensure sound reproduction of astonishing richness, precision and depth. Its extremely well thought-out and meticulous design will delight any audiophile who wants to offer their HiFi audio system complete wireless connectivity.
xxx
The Element X Core
At the base of the Element X is a powerful Quad Core ARM processor, which is responsible for processing the data. Matrix has also developed a high-quality audio system based on the Linux operating system. Unlike the brand's previous products, Element X has the ability to read files stored on your network or locally, while performing a Digital / Analog conversion. It is therefore an extremely complete product.
The ARM processor incorporates a powerful audio playback system, supporting a wide range of file formats and high sampling rates: 768kHz in PCM and native DSD up to 22.4MHz (DSD512). To enjoy your favorite songs, simply connect a USB storage device to Element X or connect a NAS to it.
Test and review by Audio Science Review
"Needless to say, the Element X comfortably takes the crown of the best DAC I have tested."
Test ASR
ES9038PRO DAC, ES9311 LDO and Femtoclock
The Matrix Element X features the latest high-end DAC chip from ESS: the ES9038PRO. This ensures a disconcertingly accurate reproduction, while offering a beautiful dynamic and a wide sound image. It comes with an ultra-low noise LDO ES9311 and a Femtoclock Crystek CCHD-950. Matrix has worked for many years with ESS chips, they provide DAC integration to maximize performance.
xxx
xxx
USB XMOS XU216 Interface
With the rapid development of high quality audio formats and the new user requirements inherent in these developments, Element X had to support many high resolution formats. Its USB interface XMOS XU216 allows it to read PCM files up to 768kHz and DSD up to DSD512. This interface also supports MQA files, a high quality format that is becoming more and more popular.
Hyper Control
In order to benefit from greater accuracy than a traditional potentiometer volume control and to avoid the dynamic disadvantages of a digital volume control, Matrix integrates a hybrid volume control design into its Element X. Thus, the device uses the digital volume of the relay matrix and DAC chip and combines analog control to maintain the advantages of each system.
xxx
xxx
Preamp section
If you want to use the Element X with active speakers, it is not necessary to add a preamplifier. Indeed, the latter has a configurable analog preamp section with a gain of +10dB.
Balanced headphone amplifier
The Matrix Element X also features a balanced headphone amplifier, based on four independent TI LME49600 high-fidelity audio buffers, so it is perfectly possible to use a headphone in symmetrical mode. When used in unbalanced mode, this section behaves like two independent stereo amplifiers, allowing two unbalanced headphones to be associated with it.
xxx
A complete and efficient connectivity
The Matrix network player has a built-in connector, allowing you to connect many devices to it to create a versatile and powerful audio system. This includes two Toslink Optics and two Coaxial SPDIF inputs, as well as I2S LVDS via HDMI and USB-B 2.0. In addition, there are 2 USB-A 2.0 ports for your storage devices (USB sticks, hard disks, etc.), a Micro SD slot and of course an RJ45 port. A pair of antennas greatly improves the reception distance of the device.
On the output side, the Element X offers on its rear side RCA Stereo and XLR but also on its front side two 6.35mm jacks, also usable in XLR 3 poles, as well as a XLR 4 poles balanced.
xxx
xxx
Control playback from your smartphone
For a simple and intuitive control of its reader, Matrix has specially developed an Android application. This allows you to browse and launch your audio files, whether they are stored on storage devices connected to the device or your local network. Matrix will also provide regular updates to improve the user experience and develop an iOS version of the application.
DLNA & Airplay
Today, media streaming via a local network has become commonplace. As a result, Matrix Element X supports DLNA and AirPlay protocols to allow you to stream your music directly from your smartphone or other compatible mobile device.
xxx
xxx
MQA Support
MQA is a high-resolution audio encoding technique with a high sampling rate while ensuring small file sizes. The MQA is therefore an ideal format for enjoying high quality audio streaming.
Strong power supply stage
Power supply is the entry point for all electrical / electronic devices and plays a major role, especially in the case of a high fidelity audio system. Matrix has therefore chosen to integrate a Noratel custom toroidal transformer and high quality Nichicon capacitors into its Element X. There are also power separators and LDOs on a 4-layer PCB. This power supply section provides the entire circuit with a clean electrical signal for a highly transparent sound.
xxx
xxx
Shielded housing
As each material has its own resonance frequency, Element X was designed with a double structure. The inner shell uses galvanized metal folded with reinforcing ribs to ensure durability. The outer shell is made of 4mm thick Aluminium. The assembly of these two materials makes it possible to modify their resonance frequencies and reduce the negative impact of resonances on sound reproduction.
Modern design
The Element range from Matrix has removed all unnecessary visual elements to give their devices a modern and high-end look. The Element X thus presents simple lines in a CNC machined Aluminium casing. It will integrate seamlessly into a high-end HiFi system.
xxx
Comparaison of Matrix Devices
Spec DeviceElement XElement PElement MElement IMini-i 3Mini-i Pro 3
DAC chipES9038 PRO + ES9311ES9028 PROES9038Q2M
DAC ChipXMOS U216XMOS U208XMOS U216
PCM : 16-24Bit 768kHz
DSD : 11.2MHz (DoP)
DSD : 22.4MHz (Native)
PCM : 16-24Bit 384kHz
DSD : 5.6MHz (DoP)
DSD : 11.2MHz (Native)
DSD : 11.2MHz (DoP)
MQA : 24bit 384kHz
DSD : 11.2MHz (DoP)
ClocksCrystek CCHD-950
Ultra Low Phase Noise
Femtosecond
SiTime Low Phase NoiseCrystek CCHD-950
Femtosecond
Digital InputsOptiquex2x1
Coaxialx2x1
I2S (LVDS)x1
Bluetooth
Réseau
USBx1 USB-Bx1 USB-C
Line InRCAx2
Line OutRCAx1x1
XLRx1x1
Amplified output2×230W@4Ω
Headphone OutXLR4 & Dual XLR3x1
Single-Ended 6.35mmx1x1
Balanced 4.4mmx1
NetworkLAN10BASE-T/100BASE-TX
WLAN2.4GHz/5GHz
IEEE 802.11
a/b/g/n/ac
2.4GHz
IEEE 802.11
a/b/g/n
Non2.4GHz/5GHz
IEEE 802.11
a/b/g/n/ac
Volume controlHyper-Control
Relay + Digital Volume
MUSES 72320
Volume resistor network
Digital volume
Storage DeviceTF Card
USB HOST X2
USB HOST X2
NAS SupportSMB V1.0 & V2.0
ARMQuad-CoreDual-CoreSingle-Core
DriveLocal filesMP3 , WMA , WAV , AIF, AIFC, AIFF, AAC, FLAC, OGG, APE, ALAC, M4A, DSF, DFF
AirplayAirplay 1Airplay 2
DLNA
Roon Ready
MQADecoder + RendererDecoder + Renderer
IR remote
Power SupplyLinear Noratel
40W
Linear Noratel
25W
Linear
30W
External AC Adapter
20W
Linear Noratel
20W
Dimensions340×281×60mm275×281×60mm240×220×55mm223x205x48mm
Weight4.2Kg4.7Kg3.7Kg1.5Kg1.7Kg
Product typeStreamer
Supported file formatsMP3, WMA, WAV, AIF, AIFC, AIFF, AAC, FLAC, OGG, APE, ALAC, M4A, DSD, DFF
PCM Sampling rateUp to 32bit 768kHz
DSD Sampling rateUp to DSD1024 (45MHz)
Supported protocolsDLNA
Airplay
DAC ChipES9038PRO
USB InterfaceXMOS XU216
Digital inputs
2x SPDIF CoaxialPCM up to 24bit 192kHz
DSD (DoP) up to DSD64
2x Optical ToslinkPCM up to 24bit 192kHz
1x I2S LVDS HDMIPCM up to 32bit 768kHz
DSD (DoP) up to DSD256
DSD (Natif) up to DSD1024
1x USB-B 2.0PCM up to 24bit 768kHz
DSD (Natif) up to DSD 512
2x USB-A 2.0 HostFor storage peripherals
NetworkLAN : 10BASE-T/100BASE-TX
WLAN : 2.4GHz/5GHz, IEEE 802.11 a/b/g/n/ac
Line outputs
1x XLR 3 poles stereoSNR : > -131dB
THD+N : < 0.00012% @ 1kHz, < 0.00025% @ 20Hz-20kHz
Frequency response : 20Hz-20kHz +/-0.05 -3dB @ 120kHz
Crosstalk : > -145dB
Output level : 4.5VRMS @ 0dB, 15.8VRMS @ +10dB
1x RCA StereoSNR : > -124dB
Frequency response: 20Hz-20kHz +/-0.05 -3dB @ 105kHz
Crosstalk : > -137dB
Output level : 2.3VRMS @ 0dB, 8VRMS @ +10dB
Headphone outputs
1x XLR 4 poles
SNR : > -117dB
THD+N : < 0.00055% @ 20Hz-20kHz 1VRMS
Frequency response: 20Hz-20kHz +/-0.05 -3dB @ 50kHz
Output impedance : < 1.5 Ohm
Output level : 1700mW @ 33 Ohm, 1180mW @ 300 Ohm, 650mW @ 600 Ohm, 1%THD
Gain : Low = +18dB / High = +28dB
2x Jack 6.35mm TRSSNR : > -112dB
Frequency response : 20Hz-20kHz +/-0.1 -3dB @ 50kHz
Output level : 1150mW @ 33 Ohm, 308mW @ 300 Ohm, 152mW @ 600 Ohm, 1%THD
Power supplyAC 220-240V 50/60Hz
AC 100-120V 50/60Hz
Dimensions340 x 281 x 60mm
Weight4.2kg
Package1x Matrix Element X
1x Power cable
1x USB cable
2x WiFi antennas
1x RM3 remote control
InputWiFi
InputMicro SD
InputI2S via HDMI
InputRJ45
OutputJack 6.35mm
DAC / ADC ChipES9038PRO
Max sampling rate768kHz
Max sampling rateDSD1024
ColorSilver
Remote ControlYes
Streaming services & Network protocolsQobuz
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsRoon / Roon Bridge / Roon Ready
Streaming services & Network protocolsTidal
2 reviews
Matrix Audio Element X
Excellent DAC, running as a ROON end point. Superb in every way, no regrets. Just be careful with the remote control, I thought mine was broken, but in fact it has different setup codes, and mine did not work out of the box and the instructions were not obvious, luckily I checked before returning the DAC for nothing !
This review has been posted for MATRIX ELEMENT X Streamer DAC ES9038PRO XMOS WiFi Femtoclock 32bit 768kHz DSD1024
C.R d’écoutes Matrix ElémentX, A1 d’Audio-GD, etc
C.R d’écoutes d’un système composé d’un Matrix ElémentX, A1 d’Audio-GD, etc.
Tout d’abord, un grand Merci à l’équipe Audiophonics pour les conseils et échanges nombreux afin de choisir les équipements venant remplacer les anciens (d’origine LINN et qui font des heureux chez leurs nouveaux propriétaires). Sans eux, pas de Matrix ni d’Audio-GD.
Les éléments qui ont été achetés chez Audiophonics sont: L’ElémentX, L’A1, les câbles de modulation, secteur, les filtres actifs et la multiprise Filtrée/non filtrée.
Je ne peux pas séparer les différents équipements pour donner une note à chacun. Tous comptent, à un niveau différent, mais sont un tout. Par exemple, j’ai changé de meubles dans la pièce d’écoute entre deux et j’ai été obligé de changer des éléments d’amortissement pour retrouver le « même » son/rendu qu’auparavant !
CR d’écoute système composé de :
Pièce d’écoute semi-réverbérant 40m2, en L avec un mur latéral semi-ouvert sur le reste de la maison. Distance d’écoute ~ 3.5m
Sub-Woofer PV1 (B&W) branché sur les enceintes Elfe (LEEDH) avec câbles LEEDH. Réglage d’intervention, 50Hz-20Hz. Ajusté en volume/fréquences pour couplage/raccord fréquences avec enceintes.
Enceintes Elfe (LEEDH) reliées à l’ampli A1 (Audio-GD) avec câbles doublés LEEDH 1.5m et isolés extérieurement. Placement : Ecartement, 1.7 m légèrement pincées vers la zone d’écoute et à 0.7m des angles de la pièce.
Ampli A1 (Audio-GD) relié à l’ElémentX (Matrix) en XLR symétrique avec 1877PHONO FUSION PURE XLR MKII Câble de Modulation 1.5m. Câble secteur 1877PHONO LEGION Blindé OFHC, Schuko IEC C15, 3x3.31mm² d’ 1.5m. Branché sur multiprise avec ifi Audio AC iPurifier, filtre secteur actif avec détection phase et terre. Le A1 est seul sur cette multi. Terre retirée sur prise Schuko au départ vers A1.
ElémentX (Matrix) relié au réseau en rj45 et à un HD USB directement (sans câble) par adaptateur/convertisseur USB A/B mâle/mâle avec un Jitterbug (Audioquest) entre l’entrée de l’ElémentX et l’adaptateur USB. Câble secteur PANGEA AC-14SE MKII triple blindages cardas Copper / OFC 3x2mm² 1.5m. Banché sur un port filtré Schuko, terre retirée, de la multiprise DYNAVOX X4100. Sur un port de la multiprise est branché un autre ifi Audio AC iPurifier. La multiprise est reliée au secteur par un câble secteur blindé OLFLEX 110CY 3x2.5mm².
Tous les équipements sont en phase «électrique/acoustique», sans terre, par test avec multimètre et/ou écoutes. Tous sont sur des supports essayés, cônes amortis, pointes en haut ou pointes en bas, amortisseurs en sorbothane, etc. Et le choix c’est fait sur le résultat d’écoutes, évidemment partagé par plusieurs.
Je n’ai testé de l’ElémentX que l’entrée HD USB. Il sert de DAC et de préampli pour l’A1 avec un gain à +10dB
Réglages paramètres internes autres que par (défaut) de l’ElémentX.
PCM Fiters =7(1) ; Dither =Off(On); Jitter Eliminator =Off(On) – Choix résultants d’écoutes.
Dernière chose que je ne m’explique pas. J’ai essayé le mode Bluetooth. N’y arrivant pas avec ma tablette, j’ai ajouté un dongle Bluetooth Motorola, que j’avais, sur le port USB HD libre, ça ne marchait pas (normal). J’ai oublié de le retirer et lors de l’écoute suivante, c’était mieux… ???. Il est resté depuis sur le 2ème port USB.
Lecture uniquement de fichiers en *.FLAC, 16 à 24 bits – 44.1 à 192 KHz. Tous les genres, avec 50% de Jazz, Bleues… 20% Pop, Rock, Variété… et 30% Classique, Lyrique, Symphonique….Je suis allé écouter de très nombreux concerts (l’absolu mieux).
Ouf, on passe à l’écoute (faite avec plusieurs personnes qui connaissent bien mon système, celui d’avant et le petit nouveau)
Résumé : Sublime !
L’illusion du réel est « pratiquement » parfaite
Détails :
Image grandiose, jamais projetée, toujours différente, selon la prise de son, mais plutôt derrière les enceintes.
Détails ultras fouillés, jamais « imposés » mais présents juste comme il faut, avec, par exemple, une respiration pour les chanteurs/chanteuses inouïe de naturelle. Aucun « léger voile ressenti » comme j’ai pu le lire sur un CR du net.
Une restitution incroyablement proche des timbres des instruments, qui pour moi, est souvent absente et de toute façon très difficile à obtenir fidèlement. Faire sonner un Steinway comme un Steinway et un Bosendorfer comme un….Bosendorfer. Bah, ce n’est pas du 100% (rien n’équivaut le réel), mais j’en suis véritablement très proche. A tel point, qu’un de mes amis a dit : j’aimerai faire jouer un saxo ici pour voir s’il y a une différence. Y-en-a une, mais elle est ténue maintenant.
La dynamique, fantastique, parfois on pourrait croire que la corde de guitare jouée par Eric Clapton va cassée, tellement la note arrive vite. Tout le toucher de l’artiste s’en trouve éclairé, aucune note s’additionne entre elles, mais elles se superposent, comme pour les voix dans les cœurs, chacun est entendu, c’est magnifiquement proche du réel. Tant que l’artiste ne décide pas d’arrêter une note jouée, la note jouée s’éteint lentement avec toutes les harmoniques de la note qui l’accompagnent. C’est beau.
Des exemples sur des morceaux avec anecdotes dites par les auditeurs :
Hadouk Trio - Touneblues – Baldamore En public au cabaret Sauvage.
Le pied !!! Qu’ils sont bons ces musiciens ! Sur le morceau, Tourne blues, j’ai failli vouloir ramasser la toupie qui « chante » au début du morceau et lorsque la chanteuse s’y met, ça voix est véritablement un instrument de plus dans le trio. Je ne comprends pas sa langue, mais elle berce mon cerveau.
Petrucciani – Jean-Philippe Herbien - Conférence de Presse Vol1.
En deux notes, on sait que c’est Petrucciani qui joue, avec son Steinway, aux aigus claquants et clairs ! Quelle énergie dans son jeu, totalement ressentie. Le piano entre entièrement dans la pièce avec sa dimension. La scène est holographique.
Eric Clapton - Drifting’ Blues – Slowhand At 70 Live At The Royal.
Formidable on s’y croirait, mais c’est drôle, je n’ai pas vu Eric entrer chez toi.
Nemanja Radulovic – Les 5 saisons – Vivaldi
Jamais entendue une version aussi jolie, avec un violon qui pétille de sonorités, fruité, quelles attaques, et ce ressenti du grain de l’archet sur les cordes, comme en vrai !
Natalie Dessay - Les contes d’Hoffmann Acte. III - Monte Carlo Philharmonique Orchestra
Planque tes verres en cristal, elle va tout prêter et je comprends toutes les paroles, d’habitude, ce n’est pas le cas.
Pink Floyd – If – Atom Heart Mother (MFSL)
Ah, je n’avais pas remarqué qu’ils chantent à trois, dès le début du morceau, je ne les entendais que sur la dernière reprise, où ils chantent clairement à trois !
Voir suite sur le Blog Audiophonics : https://www.audiophonics.fr/fr/blog-diy-audio
 (5)
 (3)
Matrix presents the Element X, a high-end network drive that is versatile, powerful and aesthetically pleasing. It opens the doors of high-fidelity...
