MINIDSP SHD Digital Signal Processor DSP SHARC ADSP21489 Dirac Live DAC / ADC Volumio Streamer
The SHD (for Streaming High Definition) of MiniDSP is a network player with digital audio processor (DSP) SHARC ADSP21489 and integrated acoustic correction solution Dirac Live. It allows you to stream audio files very simply while offering the possibility to correct the stereo audio signal according to the room in which your audio system is integrated.
4.0 / 5
By buying this product you get 159 loyalty points
Reference : 13782
1 590,00 €tax incl.
1 325,00 € tax excl.
Shipping date: 14-03-2025.
MiniDSP SHD neo3
Digital Signal Processor DSP SHARC ADSP21489 Dirac Live Volumio Streamer
MiniDSP SHD Processeur Audio Numérique DSP SHARC ADSP21489 Dirac Live Lecteur Réseau Volumio
The SHD (for Streaming High Definition) of MiniDSP is a network player with digital audio processor (DSP) SHARC ADSP21489 and integrated acoustic correction solution Dirac Live. It allows you to stream audio files very simply while offering the possibility to correct the stereo audio signal according to the room in which your audio system is integrated. The DSP allows you to act on a 10-band parameter equalizer, on crossover values up to 48dB/octave, on a compressor / limiter or a 2x4 mixing matrix for precise and fully customizable settings.
To perform digital / analog and analog / digital conversions, the SHD includes a DAC AKM AK4490EQ chip and an AKM AK5574 ADC, offering excellent performance and greatly contributing to the transparency of sound reproduction.
Measurement and correction via Dirac Live requires the use of a MiniDSP UMIK-1 microphone sold separately (see accessories).
Connectivity
The SHD offers a particularly complete connection system with USB-B and USB-A Host, RJ45 port, Toslink and Coaxial Optics as well as AES/EBU on the digital side. As an input always but this time on the analog side, there are balanced XLR and unbalanced stereo RCA. For its outputs, the SHD has two S/PDIF Coaxial connectors, 4 XLR Balanced and 4 RCA Unbalanced Stereo. This allows you to connect the vast majority of devices in your Hi-Fi audio system.
MiniDSP SHD Processeur Audio Numérique DSP SHARC ADSP21489 Dirac Live Lecteur Réseau VolumioMiniDSP SHD Processeur Audio Numérique DSP SHARC ADSP21489 Dirac Live Lecteur Réseau Volumio
Streamer
The network playback circuit is based on an ARM Quad Core processor, ensuring smooth transmission for a fully transparent music experience. The SHD is delivered with the pre-installed Volumio operating system. The latter is both intuitive and powerful, offering you the possibility to enjoy your audio files stored locally on a USB key or on a device connected to your local network (computer, NAS, smartphone...). The solution is also compatible with many streaming services such as Qobuz or Spotify as well as Internet radios.
Volumio
Technical characterstics
Product typeStreamer with integrated DSP
DSP ProcessorAnalog Devices SHARC ADSP21489 450MHz, 32bit floating point
DACAK4490EQ
ADCAK5574
Analogic output SNR120dB
Analogic output THD+N0.0003%
Max analogic output levelSingle-ended: 2V RMS
Balanced : 4V RMS
Analogic output impedanceRCA : 100Ω
XLR : 200Ω
Analogique input SNR120dB
Analogique input THD+N0.0003%
Max analogic input levelSingle-ended : 2V RMS
Balanced : 4V RMS
Analogic input impedanceRCA : 47kΩ
XLR : 48kΩ
USB InterfaceXMOS (sample rates up to 192kHz)
Acoustic correction technologyDirac Live
DSP ProcessingVolume
Parametric EQ
Crossovers
Matrix mixer
Compresser / Limiter
Mute
FIR filters storageUp to 4 FIR filters
Streamer OSVolumio
Streamer processorARM Quad Core
Inputs1x USB-B
1x Ethernet RJ45
1x USB-A (Host)
1x S/PDIF Coaxial
1x Optical Toslink
1x AES/EBU
Outputs2x S/PDIF Coaxial
4x Balanced XLR
4x Single-ended stereo RCA
CompatibilityWindows 10/11
Mac OS 10.14 ou ultérieur
Housing materialAluminium
Power supply110-240V AC
Dimensions41.5 x 129 x 236mm
Package1x MiniDSP SHD
1x IR Remote
1x Power cable
1x Mounting rack
SHD / SHD Studio Comparison
ParameterSHDSHD Studio
Channels numberInput : 2
Output : 4
Input : 2
Output : 4
InputsCoaxial, Optical, AES/EBU, USB, Ethernet, RCA, XLRCoaxial, Optical, AES/EBU, USB, Ethernet
OutputsRCA, XLR, CoaxialCoaxial, AES/EBU
Input / Output resolution32bit32bit
ADC / DAC ChipAK5574 / AK4490EQNone
Internal sampling rate96kHz96kHz
Max input sampling rate192kHz192kHz
Calibration softwareDLCT StereoDLCT Stereo
Filtering technologyDirac LiveDirac Live
Impulse response correctionYesYes
Number of onboard presets44
InputRJ45
InputXLR
OutputCoaxial SPDIF
DAC / ADC ChipAK4490EQ
Max sampling rate96kHz
Remote ControlYes
Streaming services & Network protocolsQobuz
Streaming services & Network protocolsWeb radios
Streaming services & Network protocolsTidal Connect
Streaming services & Network protocolsSpotify
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsSpotify Connect
4 reviews
Usage en crossover avec Diraclive
Acheté pour remplacer un BSS FDS 366 qui commençait à donner des signes de "fatigue", il est uniquement utilisé en crossover dans un système en bi-amplification active avec liaisons XLR.
Initialement, je comptais ne pas activer la fonction DiracLive afin de garder le système le plus neutre et le plus simple possible, en conservant les mêmes réglages que sur le BSS (forme des filtres, fréquences de coupure, retard). Mais le résultat s'est avéré plutôt décevant, avec une sensible régression en terme de plaisir d'écoute : son plus plat, plus terne, moins précis...
En désespoir de cause, je me suis donc résolu à utiliser la fonction DiracLive ; le résultat est impressionnant et j'ai retrouvé tout ce qui me manquait (dynamisme, précision, etc.) avec, cerise sur le gâteau, la possibilité de corriger un vilaine résonance qui apparaissait parfois dans les basses fréquences (pas simple de faire passer un système qui descend bas d'une maison à un appartement...).
Abstraction faite de la mauvaise information que j'ai dû compenser avec un nouveau PC (un upgrade de Win7 vers Win10 ou 11 relèvant plutôt de l'utopie), je suis 100% satisfait de cet achat.
Côté ergonomie, le réglage des filtres est assez simple (même si je regrette un petit peu la rigueur technique de la programmation du BSS) et le processus de configuration initial de DIRACLive est plutôt bien cadré.
NB : un grand pied de micro est indispensable pour les prises de mesure autour du point d'écoute.
This review has been posted for MINIDSP SHD Digital Signal Processor DSP SHARC ADSP21489 Dirac Live DAC / ADC Volumio Streamer
Documentation pas à jour
Attention la documentation téléchargeable sur le site audiophonics ne correspond pas au modèle livré (juin 2022) : en particulier contrairement à ce qui y est spécifié, Win7 n'est pas compatible... Savoir que l'achat d'un nouveau PC est indispensable, n'est pas complètement neutre.
En attendant, il ne m'est pas possible de tester l'appareil.
Le fabricant ne nous a malheureusement pas prévenu de ce changement, nous mettons la fiche produit à jour au plus vite.
A noter que vous n'avez pas à changer d'ordinateur pour mettre à jour Windows.
couteau suisse
Voilà un appareil qui réunit plusieurs fonctions, filtre actif et surtout Dirac Live, une écoute très détaillée.
Utilisé comme préamplificateur pour la gestion des sources et le volume.
2 paires de sortie stereo parametrable (gamme de fréquence, crossover, pente etc...) en XLR ou RCA. Utilisé chez moi vers des panneaux isodynamique en fullrange pour 2 des sorties et 2 subwoofers audiophiles pour les 2 autres sorties. Le crossover le gain et les pentes sont gérés via le SHD et son logiciel sur Mac ou PC (donc avec representation graphique).
Ensuite et c'est là une des forces de ce processeur, passage à l'analyse de la réponse de l'ensemble (HPs et pièce d'ecoute) grâce a la fonctionnalité Dirac Live (via un ordinateur connecté au SHD). Et le résultat est bluffant.
DAC par ailleurs excellent.
Volumio disponible mais non utilisé. Il ne manque qu'une connectivité airplay pour satisfaire quelques invites de passage.
Doc exhaustive et super détaillée disponible sur le site Minidsp
The SHD (for Streaming High Definition) of MiniDSP is a network player with digital audio processor (DSP) SHARC ADSP21489 and integrated acoustic...
