NANOSOUND PLAYER Volumio Streamer Kit PCM5122 DAC 24bit 192kHz
The NanoSound Player is a networked player with DAC in reduced format, running under Volumio and completely ready for use. Its design, oriented around Open Source components and software, makes it completely customizable.
POINTS CLÉS :
  • Volumio
  • DAC PCM5122
  • IR Remote Controle
  • 24bit 192kHz
4.0 / 5
By buying this product you get 20 loyalty points
Reference : 12414
209,00 €tax incl.
174,17 € tax excl.
Nanosound Player
Audiophile Streamer with Volumio
Nanosound player lecteur réseau dac
A good DIY streamer
The NanoSound Player is an Audiophile network player kit, with Volumio pre-installed on the Micro SD card. The kit integrates all the components that allow it to work and to have an efficient ergonomics. It contains an OLED screen, control buttons and a remote control, the Raspberry Pi, Micro SD card (with Volumio) and power supply.
The NanoSound is therefore delivered directly with its software solution installed on the Micro SD card provided, namely Volumio. This player will allow you to simply control your music, via a web interface, from any connected device.
Volumio
Presentation video NanoSound & Volumio
Upgrades possibilities
If the NanoSound Player can work alone without any problem, it can also be paired with the NanoSound AMP^2. This amplifier has a 5W amplifier that allows you to power small systems but also a headset amplifier section.
Small size, elegant design
The NanoSound Player system integrates into a black box designed for the 3D printer. Very sober and aesthetic, it will integrate seamlessly into the vast majority of audio systems.
A customizable system
The NanoSound Player is completely customizable thanks to the Raspberry Pi's free architecture. Thus, the 6 buttons present are GPIO buttons, and the Python code is provided. Likewise, the IR receiver is LIRC compatible and the lircd. conf configuration file is also provided. On the display side, the OLED 1.3" screen uses I2C and the Python code allowing the display is Open Source. Finally, the Raspberry Pi's ON/OFF switch uses software already used by the brand and Open Source.
Caution: the spacers and screws provided enable mounting on the Nanosound Amp. Mounting the Nanosound player directly on the Raspberry Pi can be done without spacer. You can still buy spacers separately to bring greater support to the set.
DACBurr-Brown PCM5122
Sampling rates24bit 192kHz
Voltage regulatorsTexas Instruments TPS7A4700 Ultra Low Noise
Power supplyPower via Micro USB or external power supply
ON/OFF Switch Raspberry PiYes
GPIO buttons for media controlx6
IRIR receptor with remote control
DisplayOLED Screen 1.3" 128x96px with multi-languages support
Case3D printing plastic
Package1x Raspberry Pi 3 Model B
1x Raspberry Pi Power Supply
1x NanoSound DAC with remote control and OLED screen
1x Micro SDHC Sandisk Ultra 16GB card
1x Black Case
InputRJ45
OutputJack 3.5mm
DAC / ADC ChipPCM5122
Max sampling rate192kHz
Fait le Job
Fait le job et même très bien.
Facile à mettre en oeuvre, facile à utiliser
This review has been posted for NANOSOUND PLAYER Volumio Streamer Kit PCM5122 DAC 24bit 192kHz
The NanoSound Player is a networked player with DAC in reduced format, running under Volumio and completely ready for use. Its design, oriented...
