NATIV VITA - Hifi Streamer with Touchscreen DSD256 32bit 384Khz Maple Stand
By buying this product you get 159 loyalty points
Reference : 12263
1 599,00 €tax incl.
1 332,50 € tax excl.
This is the Maple version, with maple base (light wood)
NATIV VITA Maple
Touch network player Hifi
Nativ Vita lecteur réseau
An exceptional sound, a revolutionary control.
Nativ presents the Vita, a network player for your High Definition music with touch control. It allows you to enjoy instant access to your music via your favorite music services like Qobuz, Apple Music, Spotify or Tidal, but also music stored on your computer, NAS or smartphone. The Vita is a bit-perfect solution, which will connect easily to your wireless speakers, your USB DAC or A / V receiver.
Touchscreen 11.6"
To simply control your music, the Nativ Vita is equipped; of a beautiful LCD screen IPS high-resolution, offering a magnificent and bright image, no matter the angle of view.
An audiophile design
The Vita incorporates high-quality digital outputs, such as an asynchronous USB 2.0, SPDIF (RCA, TosLink, BNC) and AES / EBU (XLR). The unit supports resolutions up to DSD256, DXD and PCM 32bit / 384kHz.
Advanced connectivity
Supporting Wifi 802.11ac, Ethernet Gigabit and Bluetooth aptX, but also Airplay, Spotify Connect and Google Cast, nothing limits your access to your music.
Applications & voice control
You can download iOS and Android apps to control the device directly from your smartphone or enjoy Native Vita's voice control for easy control.
Multiroom
Designed to work in multiroom, you can stream your music throughout your home, play the same or different songs, via your networkWifi, Airplay or Bluetooth.
Up to 4Tb of Storage
With 2 slots for SSD, you can have up to 4TB of data storage, for example 8000 albums or 40000 titles (SSDs are not included).
innovative
You can simply browse the music of your Mac, PC or NAS via the superb display and the Roon interface, while enjoying the exceptional sound quality of the Vita (requires Roon software - paid subscription not included).
TV Interface
By connecting the device to your TV via HDMI, Google Cast or Apple TV you can enjoy the Vita interface on the big screen.
The screen, centerpiece.
The centerpiece of the Nativ Vita is its high-resolution 11.6 "LCD touchscreen LCD.read more conveniently than most other solutions.
Nativ-Vita-High-Resolution-Music-Player-
All your music at your fingertips.
The Nativ Vita allows you to simply centralize your music. So you can enjoy music stored on your network devices (computer, NAS, smartphone). The Vita also incorporates the main protocols, such as UPnP / DLNA, playback via SMB / CIFS or Airplay. Kodi, Plex, JRiver or Roon ... More than that, Nativ Vita allows you to access a wide range of audio streaming services, allows you remote control via smartphone or tablet.
4Tb possible only for your music
If you can access your networked music, the Nativ Vita is also equipped with two slots to add up to 4TB of storage for maximum performance. So, no problem related to streaming, you take full advantage of your high songsresolutions.
Exceptional design
The Nativ Vita has been designed exclusively for music and offers a high quality design. Thus, the device incorporates independent power regulators, galvanic isolation and an in-line filter for the digital section, thereby reducing electrical noise. Components carefully integrated into a premium aluminum chassis, eliminating virtually any unwanted EMI and RFI that could interfere with sensitive audio signals.
Its sleek, modern design will fit seamlessly into your audio system. Designed from exclusive materials including Aluminum 7000 series with satin finish, Japanese Asahi® glass and solid wood from America.
Test and review by Darko Audio
Ultimately, I find the Vita far from out of place fronting a rather expensive headphone-based rig, despite it being the most affordable component in the chain. It’s that good. And when you factor in the support for various music streaming services, many of which aren’t found on any other device, irrespective of price, the Nativ Vita is contrasted as something very special indeed.
test by the reviewer Darko Audio
components
  • A6 Multi-Core Cortex Processor
  • RAM: 4Gb
  • Wifi Dual-Band 802.11 a / b / g / n / ac
  • Ethernet Gigabit
  • Touch screen Full HD LCD IPS 11.6 "/ Li>
Sources of music
  • Apple Music, Spotify, Pandora, Tidal ...
  • Internet radios
  • Shared libraries on PC / Mac / NAS via UPnP / DLNA or SMB / CIFS
  • Smartphone and tablets
Audio Outputs
  • S / PDIF (Coax):
    • 1x RCA, 1x BNC
    • Unbalanced, 75 Ohms
    • PCM 24bits 192kHz
    • DSD via DoP: DSD64 arranged in PCM frames at 176.4kHz
    • Native DSD64
  • S / DIF (Optical):
    • 1x Toslink
    • PCM 24bits 96kHz
  • AES / EBU:
    • 1x XLR
    • Balanced, 110 Ohms
    • PCM 24bits 192kHz
    • Native DSD64
  • USB 2.0 HS (480Mb / s):
    • Asynchronous USB, Audio Class 2.0
    • PCM 32 bit 384kHz (driver required for Windows)
    • DSD via DoP: DSD64 arranged in frames PCM at 176.4kHz, DSD128 in frames of 352.8kHz
    • Native DSD64, DSD128, DSD256
Audio Inputs
  • 1x RCA Stereo
  • 1x Coaxial
  • Bluetooth compatible aptX
Formats and sampling
  • WAF, AIFF, ALAC, FLAC, AAC, MP3, OGG, DSD64, DSD256, DXD
  • Sample rate: 44.1 to 384kHz at resolutions 16, 24 and 32bit
  • Reading without white
Dimensions, weight and contents
  • Cut :
    • Network audio player: 28.5 x 21.8 x 4.5cm
    • Support: 28.5 x 3.5 x 13.5cm
  • Weight:
    • Network audio player: 2.4kg
    • Support: 0.35kg
  • Content: Nativ Vita Audio Network Player, Support, User's Manual, IR Remote Control, Power Cable.
InputWiFi
InputRJ45
OutputHDMI
OutputOptical Toslink
OutputCoaxial SPDIF
OutputBNC
Max sampling rate384kHz
Max sampling rateDSD256
ColorOther
ColorWalnut
