RASPTOUCH AMP Streamer / Amplifier ES9023 & TPA3118 2X30W
By buying this product you get 37 loyalty points
Reference : 12102
379,00 €tax incl.
315,83 € tax excl.
RASPTOUCH AMP ES9023 TPA3118
Streamer, DAC and amplifier
RaspDAC AMP ES9023 TPA3118
Audiophonics unveils its RaspTouch Amp ES9023, a brand new version of its ready-to-use RaspTouch. In fact, it incorporates an I-Sabre Amp DAC ES9023, with the particularity of combining both an ES9023 converter and a Class D 2x30W TPA3118 Class D amplifier. Simply plug in your speakers and enjoy the music stored on your server or locally.
Rasptouch AMP ES9023 TPA3118
piCorePlayer
max2play
OSMC
Complete compatibility
With the RaspTouch Amp 9023 you are completely free to choose the operating system that best suits your preferences and needs.
Ready to use electronically, many software solutions exist to meet all your expectations: piCorePlayer, Max2Play, OSMC...
Multiroom without limits
Do you want to enjoy your music throughout your home? The Rasptouch offers you an efficient multiroom system, allowing you to stream your files on any turntable connected to your network and control them.
An High End audio player thanks to the ES9023 and TPA3118
ES9023 DAC
With its I-Sabre ES9023 converter, the RaspTouch Amp is capable of playing high-resolution audio files, up to 24bit 192kHz. A clock complements this one to reduce the jitter drastically, to offer you an excellent sound reproduction.
TPA3118 AMPLIFIER
The DAC ES9023 is backed by a Class D TPA3118 amplifier from Texas Instrument, which delivers 2x30W power at 8 Ohms with a high efficiency of over 90%. The TPA3118 incorporates an advanced oscillator/PLL using frequency switching technology to avoid AM interference. In addition, the amplifier incorporates numerous protections against short circuits, excessive temperatures and over/undervoltages. This prevents damage to the equipment.
Raspberry Pi
Version 3 Model B+
ESS DAC
ES9023
Texas Instrument Amplifier
TPA3118
Ergonomic and Design
Featuring a 7"touch screen, it allows you to easily and intuitively control your audio library via a graphical interface.
Mounted in a 100% CNC-machined aluminium housing in France, its black colour and matt appearance give it a modern and contemporary design. A device that will fit perfectly into your high-end audio system.
Connectors
Raspberry Pi Inputs4x USB-A
1x Ethernet RJ45
1x Micro SD
Raspberry Pi Outputs1x HDMI
ES9023 Outputs1x Stereo RCA
Raspberry Pi 3 B+
SoCBroadcom BCM2837B0
CPUARM Cortex-A53 1.4GHz 64bit
Wifi802.11n
Bluetooth4.2
GPUMultimédia IV Videocore Coprocessor Dual Core
RAMLPDDR2 1Go
ES9023 DAC
Clock1x
Sampling rate24bit 192kHz
Capacitors2x Condensateurs électrolytique 50V
TPA3118 Amplifier
TypeClass D
Ouput power2x30W @ 8 Ohm
Efficiency> 90%
ProtectionsShort circuit
Temperature
Surge
Screen7" Capacitive tactil
Screen resolution800 x 400px
Case colorBlack
Case materialAluminium
AccessoriesPower supply DC 5.5 / 2.5mm 24V 4A
RaspTouch AMP ES9023 TPA3118
InputRJ45
InputMicro SD
OutputSpeaker terminal
OutputHDMI
DAC / ADC ChipES9023
Max sampling rate192kHz
