RASPTOUCH DIGIONE Touch Screen Streamer with Digital Output WM8805 Black
The Rasptouch DiGiOne Audiophonics Rasptouch streamer features a 7" touchscreen interface with high fidelity sound on digital outputs with very low jitter. Thanks to the quality of its ALLO DiGiOne digital card, Raspouch is the ideal companion.
Key features :
  • responsive and legible touch screen display
  • Low jitter digital output interface
  • Aluminium case
  • ATX type power mangement system for RPI3
  • piCorePlayer
By buying this product you get 43 loyalty points
Reference : 12429
439,00 €tax incl.
365,83 € tax excl.
RaspTouch DIGI ONE
Network player with SPDIF 75 Ohm digital output
The RaspTouch is evolving! Equipped this time with the excellent ALLO DIGIONE SPDIF interface, it offers a noticeable improvement in terms of ergonomics and a Coaxial SPDIF port doubled by a BNC gold-plated 75 ohm.
Full compatibility with piCorePlayer
The Rapstouch DiGiOne comes with piCorePlayer system installed on the supplied Micro SD card. This way, you can enjoy your streamer directly without having to install an OS beforehand.
Working video of Rasptouch and piCore player interface here
High-end audio player thanks to the ALLO DIGIONE
This version of the Rasptouch has to date the most powerful version of digital SPDIF interface dedicated to the Raspberry Pi 3 B+. The ALLO DiGiOne has technical refinements at the level of the best Hifi High end production with one of the best implementations of the digital receiver DIR WM8805. This board has 10 LDO (low drift) regulations, high quality galvanic isolation and a Japanese NDK low jitter clock with 0.4 pico second.
Essai du ALLO DIGIONE PAR Hans Beekhuzen
A complete connection system
The DiGiOne Rasptouch offers a complete connection system that will suit most needs. So you'll find 4 USB 2.0 ports and an Ethernet RJ45 port to enjoy your music locally or from your network and an RCA Coaxial, BNC 75ohm and HDMI output. So you have a panel of connectors at your disposal to enjoy your entire audio library.
Sober and elegant design
Mounted in a 100% CNC-machined aluminium housing in France, its black colour and brushed matt appearance give it a modern yet elegant design. It will integrate seamlessly into your high-end audio system.
Rasptouch Boîtier
Input connectivity
USB-A 2.0x4
Ethernet RJ45x1
Slot Micro SDx1
output connectivity
Sortie numériquex1 coaxial x1 BNC 75ohm
HDMIx1
Connectiques : Sorties
HDMIx1
Raspberry Pi 3 B+
ChipsetBroadcom BCM2837B0
ProcesseurCortex A53 64bit SoC 1.4GHz
Wifi2.4GHz et 5GHz IEEE 802.11 b/g/n/ac
Bluetooth4.2
RAM1GB LPDDR2
ALLO DIGIONE GPIO CARD
Sampling max frequencyTo 24bits 192kHz
Jitter06 Pico Seconde
Noise Level50uV
BrandALLO
Screen & material
Touch screen7" tactile capacitif 800 x 400px
Frame materialAluminium
ColorsBlack
VArious
PowerJack DC 5.5/2.1mm - 7.5V 2.9A (fourni)
AccessoryCarte Micro SD, power adaptator supply
Delivered with piCorePlayer installed
InputMicro SD
InputBNC
InputRJ45
OutputBNC
OutputHDMI
OutputCoaxial SPDIF
Max sampling rate192kHz
J'ai acquis ce lecteur réseau depuis un mois et après une bonne semaine pour maîtriser la bête, je suis plus que satisfait. La première impression a été la "Clarté" !!! J'utilise le RasTouch alimenté avec une alim linéaire Audiophonics, connecté à un DAC Audiophonics AKM 4495SEQ, Vecteur I4.2, Apertura Thema, câblages Audiophonics, pour lire ma collection de cd ripés avec Exact Audio Copy sur un disque dur. Par rapport à ma platine cd de marque anglaise, j'ai retrouvé le son analogique, mais en plus précis dans tous les registres. Les détails sont là, la prise de respiration des chanteurs, le glissé des doigts sur les cordes de guitares malgré l'accompagnement d'un orchestre symphonique, le cliquetis d'un pédalier d'orgue, des cris d'enfants dans une cours d'école ou un hélicoptère qui passe de gauche à droite en fond derrière une grosse orchestration... Les graves sont plus ferme et la spatialisation sans commune mesure avec ma platine cd. Donc en conclusion je ne peux que recommander, je n'ai pas trouvé mieux avec le matériel proposé par un magasin audiophile à prix cinq fois supérieur ... Un grand merci à l'équipe Audiophonics qui a été d'une efficacité redoutable face a mes appréhensions sur la configuration de PicorePlayer. Pour information, évitez d'écrire le nom vos réseaux wifi, mots de passe, disques durs avec des symboles autres qu'alphanumériques... Une semaine pour paramétrer mon réseau car il y avait des : & _ et autres @....
This review has been posted for RASPTOUCH DIGIONE Touch Screen Streamer with Digital Output WM8805 Black
The Rasptouch DiGiOne Audiophonics Rasptouch streamer features a 7" touchscreen interface with high fidelity sound on digital outputs with...
