TEMPO eC2A CD Player DAC USB ES9023 Headphone Amplifier
By buying this product you get 32 loyalty points
Reference : 9880
329,00 €tax incl.
274,17 € tax excl.
This TEMPO eC2A CD player has been designed around a Philips 7824 servo and a SANYO HD850 laser scanner.
It is equipped with the famous ESS ES9023 saber converter and a TPA6112A2 headphone amplifier that can drive headphones up to 600 ohms.
The high-quality components (Nichicon, Rubycon condensers, etc.) have been chosen with the aim of offering you the best for a result of a high precision and a musicality that will make your listening more pleasant.
Characteristics :
  • SANYO HD850 Laser Reading Head
  • Servo Philips 7824
  • DAC USB
  • ESS Switching Converter ES9023
  • Integrated Headphone Amplifier TPA6112A2
  • Output Level: 2V
  • Headphone output level max. : 100mW at 32 Ohm
  • Frequency response: 20Hz - 20kHz to +/- 1dB
  • Noise Ratio: 105dB
  • THD + N: <0.005% (1kHz)
  • Headphone Jack Out 6.35mm
  • Analog output: RCA
  • Digital Output: Coaxial SPDIF
  • USB 2.0 port
  • Dimensions: 295x192x104mm
  • Weight: 3.5kg
  • Remote control and power cable supplied
[Img-11890-left-thickbox_default]
[Img-11891-left-thickbox_default]
[Img-11892-left-thickbox_default]
[Img-10869-left-thickbox_default]
[Img-10870-left-thickbox_default]
[Img-10871-left-thickbox_default]
[Img-10872-left-thickbox_default]
[Img-10873-left-thickbox_default]
[Img-10874-left-thickbox_default]
