DAYTON AUDIO DAX88HUB Keypad Hub for DAX88
New
The DAX88 lets you connect up to eight control keyboards per device. With the DAX88HUB, you can connect all your keyboards to the DAX88 with a single Ethernet connection.
Reference : 20645
119,00 €tax incl.
99,17 € tax excl.
This product is temporarily unavailable.
    Dayton Audio DAX88HUBKeypad Hub for DAX88
    Dayton Audio DAX88HUB picture
    The DAX88 lets you connect up to eight control keyboards per device. With the Dayton Audio DAX88HUB, you can connect all your keyboards to the DAX88 with a single Ethernet connection. Each keyboard connects directly to the DAX88HUB via an Ethernet cable. The DAX88HUB then connects to the DAX88 with a single Ethernet cable to simplify installation and reduce cable clutter.
    Dayton Audio DAX88HUB connection
    Product typeKeyboard control hub
    Connectors8x Ethernet RJ45 for keypad
    1x Ethernet RJ45 to DAX88
    Dimensions48.3 x 4.5 x 5.7cm
    Package1x Dayton Audio DAX88HUB
    The DAX88 lets you connect up to eight control keyboards per device. With the DAX88HUB, you can connect all your keyboards to the DAX88 with a...
