Easy to install - works well
The iFi Audio LAN iPurifier Pro optical galvanic isolator lets you optimize the LAN Ethernet connection of your audio equipment. Galvanic isolation technology converts the incoming network signal via RJ45 into an optical signal, removing any noise present in the original signal while improving jitter before converting it back to output on a second RJ45 port. The two RJ45 Ethernet ports are based on the IEEE 802.3x standard, with speeds of up to 1000/100/10Mbps (10/100/1000Base-T). LEDs keep you informed of the device's operating status. Power is supplied via a USB-C port (5V - 1A). A USB power adapter with cable and RJ45 network cable complete the package.
Product type | Network isolator |
Interface | 2x RJ45 |
Ethernet standard | IEEE 802.3x |
Supported speeds | 1000/100/10Mbps (10/100/1000Base-T) |
Power supply | USB-C 5V 1A DC |
Dimensions | 99 x 92.8 x 24.2mm |
Net weight | 241g |
Color | Gray |
Package | 1x IFI Audio LAN iPurifier Pro 1x RJ45 cable 1x Power adapter with USB-A to USB-C cable |
Length (m) |
Shielding |
Section (mm²) |
Connector |
Conductors material (Cable) |
Conductors Plating (Cable) |
Average votes 5.0 / 5 4 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
David O.
Antoine S.
Jerome D.
Gérard P.
