LHY AUDIO SW-10 Network Switch Gray
LHY Audio offers us their SW-10 network switch. This switch features 8 RJ45 Ethernet ports, 2 SFP fiber optic ports and an input and output connected to the 10mHz OCXO clock. All of this is housed in an elegant anodized aluminum case, machined from solid, and designed to separate AC power processing, DC power processing and audio signal processing.
By buying this product you get 189 loyalty points
Reference : 19170
1 890,00 €tax incl.
1 575,00 € tax excl.
LHY AUDIO SW-10 Network Switch 8x RJ45 2x Optical Fiber Gray
LHY AUDIO SW-10 : Front view
LHY Audio SW-10: A noise-free, stable power supply
For its power supply, the SW-10 deploys two Talema 15VA encapsulated transformers coupled to an RFI suppression filter. Once transformed, the current passes through a low-drop multi-stage low-dropout voltage regulator and a voltage rectifier to ensure the cleanest possible power supply.
LHY Audio SW-10 : An OCXO master clock at the heart of everything
As far as signal processing is concerned, LHY Audio's SW-10 Gigabit switch circuit is based on Cisco's professional series. This network switch offers 8 RJ45 Ethernet ports and 2 SFP optical fiber ports. Not only that, the SW-10 has a 10mHz OCXO clock at its heart, linked to a BNC input and output. So you can use this network switch as a master clock to synchronize other external sources, or simply resynchronize the input signal. The input is configurable as a sine wave or square wave in 50 Ω, while the output is square wave only in 50Ω or 75Ω. Finally, the OCXO clock is coupled to a PLL phase-locked loop.
Product typeOptical Fiber Ethernet Network Switch
Interface8x RJ45 ethernet port
2x SFP fiber optic connector
1x BNC input for 10MHz clock (50Ω input impedance)
1x BNC output for 10MHz clock (output impedance 50Ω / 75Ω)
Network Technology1000Base-T
1000Base-X
Power supply220V - 240V AC
Dimensions307mm x 60mm x 257mm
Weight3.95kg
ColorGray
package1x LHY AUDIO SW-10 Network Switch
1x Power supply cable
Length (m)N/A
ShieldingNC
Section (mm²)N/A
ConnectorRJ45
ConnectorBNC
ConnectorOptical
Conductors material (Cable)N/A
Conductors Plating (Cable)NC
LHY AUDIO SW-10 Network Switch 8x RJ45 2x Optical Fiber SFP Gray
LHY Audio offers us their SW-10 network switch. This switch features 8 RJ45 Ethernet ports, 2 SFP fiber optic ports and an input and output...
