LHY AUDIO SW-6 SPF Network Switch 5x RJ45 1x Optical Fiber Silver
With the SW-6 SPF, LHY Audio offers us a network switch featuring 5 RJ45 ports, one of which is digitally isolated, a fibre optic SFP port and a BNC input connected to the 10mHz OCXO clock. All this is housed in an elegant anodised aluminium enclosure machined from solid material and designed to separate AC current processing, DC current processing and audio signal processing.
By buying this product you get 85 loyalty points
Reference : 19491
859,00 €tax incl.
715,83 € tax excl.
LHY Audio SW-6 SPF Network Switch 5x RJ45 1x Optical Fiber Silver
LHY Audio SW-6 SPF : Front view
LHY Audio SW-6 SPF : A rare quality power supply
For its power supply, the SW-6 SPF deploys a Talema 15VA encapsulated transformer coupled to an RFI suppression filter. Once transformed, the current passes through a high-speed voltage rectifier, a 3-stage CLC filter circuit and finally a LT3042 + PNP linear voltage regulator. This multi-stage processing ensures a perfectly stable power supply without the slightest parasitic noise or artefact.
LHY Audio SW-6 SPF : OCXO clock and connectivity
In terms of signal processing, the LHY Audio SW-6 SPF has 5 RJ45 ports, one of which is digitally isolated, and an optical SPF port. But that's not all: the SW-6 SPF has a high-precision 10 MHz OCXO clock at its heart, itself connected to a BNC input if you wish for your network switch to be synchronised to an external clock.
Product typeOptical Fiber Ethernet Network Switch
Interface4x RJ45 ethernet port
1x Isolated RJ45 ethernet port
1x SFP fiber optic connector
1x entrée BNC pour horloge 10MHz (impédance d'entrée 50Ω/75Ω)
Power supply220V ~ 240V AC
Dimensions240 x 175 x 50mm
Weight2kg
ColorSilver
Package1x LHY Audio SW-6 SPF
1x Power supply cable
ColorSilver
Length (m)N/A
ShieldingNC
Section (mm²)N/A
ConnectorBNC
ConnectorOptical
ConnectorRJ45
Conductors material (Cable)N/A
Conductors Plating (Cable)NC
With the SW-6 SPF,  LHY Audio  offers us a network switch featuring 5 RJ45 ports, one of which is digitally isolated, a fibre...
