LHY FMC Optical Galvanic Network Isolator Black
The LHY FMC galvanic network isolator optimizes your audio system's Ethernet LAN connection. It converts the network signal into an optical signal via its SFP port, and outputs it via its galvanically isolated RJ45 port.
By buying this product you get 56 loyalty points
Reference : 19741
569,00 €tax incl.
474,17 € tax excl.
Shipping date: 22-04-2025.
LHY FMC Optical Galvanic Network Isolator RJ45 Ethernet OCXO Black
LHY FMC picture
The LHY FMC galvanic network isolator optimizes your audio system's Ethernet LAN connection. It converts the network signal into an optical signal via its SFP port, and outputs it via its galvanically isolated RJ45 port. This eliminates any noise in the signal. In addition, it features a 10MHz OCXO clock for reclocking the signal, considerably reducing jitter. DATA transfer speeds reach 1000/100/10Mbps.
All the components used in this device are of the highest quality. On the mains supply side, an AC EMI/RFI filter and a Talema transformer coupled with high-quality capacitors deliver a clean current to the entire LHY FMC. On the optical conversion side, 3 LDO LT3042 voltage regulators power the LHY FMC's clock and main board.
Photo of LHY FMC interior
LHY FMC overview
LHY FMC overview
1LED operating indicators
2SFP port
3RJ45 port
4Power on/off switch
5Fuse slot
6IEC power supply
Product typeNetwork isolator
Interface1x SFP port
1x Isolated RJ45 port
Supported transmission speeds1000/100/10Mbps
Voltage regulators3x LT3042+PNP
ClockOCXO 10MHz
LED indicatorsACT: SPF connection
LNK : DATA transmission
Power supply220/240V AC
Fuse5x20mm (10W)
Dimensions150 x 175 x 50mm
Weight1.5kg
Package1x LHY FMC
1x Power supply cable
The LHY FMC galvanic network isolator optimizes your audio system's Ethernet LAN connection. It converts the network signal into an optical...
