Dual Power Supply board for Preamplifier 4x4700µF 100V
Reference : 10227
34,90 €tax incl.
29,08 € tax excl.
Shipping date: 22-04-2025.
This dual power module allows for comfortable power in a compact volume.
Ideal for powering an Amplifier.
Thanks to the use of 8 FR104 diodes, this power supply makes it possible to reach a rectified voltage adjustable from 20 to 60V.
It is designed around TOSHIBA 2SC5171 and 2SA1930 controllers.
On the filter side, there are 2x 2 Chemi-Con capacitors each 4700μF / 100V which are used.
The output stage also benefits from first-order filtering with 2x 3 THOMPSON capacitors each of 1μF.
Characteristics :
  • Output voltage adjustable: +/- 20V to +/- 60V
  • Continuous current: 100mA
  • Input / output connections via screw terminals
  • Requires heat sink
  • Screws and spacers provided
  • Spacing: 155mm, 55mm
  • Dimensions: 165x64x44mm
  • Weight: 240g
InputScrew terminals
OutputScrew terminals
Output voltage (V)60.0
Output voltage (V)20.0
Output current (A)0.1
Input voltage (V)N/A
Power SupplyNC
Bon produit
Bonjour, il s’agit d’un bon module d’alimentation. Un grand intérêt pour la possibilité de réglage du courant de sortie selon le besoin à l’usage. Un grand remerciement au SAV pour les échanges techniques. Cordialement,
This review has been posted for Dual Power Supply board for Preamplifier 4x4700µF 100V
