Used in DAC power supply unit.
Linear, 4 Snap in 35mm slots, Gold plated
This dedicated linear power supply circuit is ideal for designing stereo DIY amplifiers. It allows you to integrate 4 35 mm Snap-In capacitors of your choice (10 mm pin-capacitor spacing). The package contains the PCB, 2 diode bridges RBV5006 and 4 screw terminals.
It is of course all possible to use other rectifier bridges with SIL box or other terminal blocks.
Product type | Power supply bard |
Available slots | 4x snap-in Ø 35mm capacitor (not included) 2x bridge rectifier 4x screw terminal block |
PCB tracks | Wide tracks, Gold plated |
Dimensions | 124 x 75 x 2.1mm |
Fixation holes spacing | 115 x 67mm |
Capacitors pins spacing | 10mm |
Weight | 40g |
Package | 1x Power supply PCB 2x Rectifier Diode RBV5006 (SIL type) 4x Screw terminal blocks |
Input | Screw terminals |
Output | Screw terminals |
Output voltage (V) | NC |
Output current (A) | NC |
Input voltage (V) | N/A |
Power Supply | Linear |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
