Power Supply board for Amplifier 4x10000µF 63V
Reference : 10215
24,90 €tax incl.
20,75 € tax excl.
This power module allows a comfortable power in a volume of restricted space.
Ideal for powering an Amplifier.
Thanks to the use of 4 diodes FCU2040A, each mounted independently on a heat sink, this power supply indeed makes it possible to reach a rectified voltage of 63V .
On the filter side, there are no less than 4 Nippon Chemi-Con capacitors each 10000μF / 63V with automatic discharge which are used.
The output stage also benefits from first-order filtering with 2 VISHAY capacitors each of 0.33μF / 160V.
Characteristics :
  • Output Voltage: 63V Max
  • Input / output connections via 6mm lugs
  • Screws, spacers and terminals supplied
  • Spacing: 120mm, 65mm
  • Dimensions: 130x75x65mm
  • Weight: 320g
InputPCB Connector
OutputPCB Connector
Output voltage (V)63.0
Output current (A)NC
Input voltage (V)N/A
Power SupplyNC
4 reviews
Bonne Alim. Y a plus qu a ... câbler.
Reçu dans les temps ...
This review has been posted for Power Supply board for Amplifier 4x10000µF 63V
bonne alim.
une bonne réserve de puissance
Super rapport qualité prix
Rien à dire j'en suis à ma troisième paire, fiable silencieux, bonne réserve de courant même sur un double mono en classe A
Conforme
RAS
