Power Supply Module for Amplifier 6x10000μF / 50V
Reference : 7942
27,00 €tax incl.
22,50 € tax excl.
Power Module for Amplifier AUDIOPHONICS 50V 10000μF
The power supply moduleAudiophonicsreference 4480allows a comfortable power in a volume of restricted space.
Thanks to the use of 4 diodes Motorola MUR860, each mounted independently on a heat sink, this power supply indeed makes it possible to reach a rectified voltage of 50V .
As far as filtering is concerned, it is no less 6 capacitorsNippon Chemi-Con of each10000uF / 50Vand automatic discharge devices that are used.
The output stage also benefits from first-order filtering with 2 WIMA capacitorsof each one100nF.
Specifications :
  • Output Voltage:/ Strong>50V Max
  • Maximum Current per Diode:8.0 Amp
  • Dimensions: 165 x 75 x 60 mm
  • Weight:500g
https://www.audiophonics.fr/images2/7942/7942_module_thumbs.png
https://www.audiophonics.fr/images2/7942/7942_module_2.jpg
https://www.audiophonics.fr/images2/7942/7942_module_1.jpg
