Linear Power Supply Board 6x 10000µF 63V 50A
This large linear power supply module is equipped with a massive QL5010 diode bridge with a heat sink, as well as 6 Nover 63V capacitors of 10000µF each, ensuring a high filtering capacity. The module supports a high current of 50A.
Product type | Linear power supply |
Rectifier | QL5010 |
Capacitors | 6x Nover 63V 10000µF |
Current | 50A |
Input | Screw terminal |
Output | Screw terminal |
Dimensions | 186 x 72 x 72mm |
Mouting holes spacing | 178 x 64mm |
Weight | 452g |
Input |
Output |
Output voltage (V) |
Output current (A) |
Input voltage (V) |
Power Supply |
