ELECAUDIO ADIACIUM GR Extensible PET braided sleeve Nylon 4-11mm
Braided sleeve made in PET (Polyethylene Terephthalate) mono-strands which can be used in a wide variety of applications.
Thanks to its expansibility, the unique PET weaving allows easy and fast installationon bulky connectors of irregular shape.
Reference : 11418
1,90 €tax incl.
1,58 € tax excl.
Shipping date: 25-04-2025.
Gaine vendue au mètre
The PET is braided from a 0.010 "monofilament of PolyEthylene Terephthalate for continuous use at temperatures between -40 ° C and 125 ° C .
Its melting temperature is 210 ° C . It has good dielectric qualities as well as excellent tensile strength and an good elasticity .
Its versatility is such that it is used in fields as varied as the automotive industry, computing, scuba diving, electronics, harnesses, audiovisual, and even some military applications.
This braided sheath was designed and manufactured in France.
Depending on the diameter of your cable, it is necessary to plan the reduction of the sheath length according to the following table:
SHEATH LENGTH ACCORDING TO CABLE DIAMETER
Cable diameterRequired sheath length
Ø4mm1m
Ø6mm1.08m
Ø8mm1.15m
Ø10mm1.3m
Ø12mm1.7m
Features :
  • For cable with a diameter between 4 and 11mm
  • Structure Polyethylene Terephthalate monofilament
  • High elasticity and excellent tensile strength
  • Temperature Resistance: -40 ° C to 125 ° C
  • Melting Temperature: 210 °
  • Color: Green khaki / Black
  • Sold by the meter
ColorGreen
MaterialNylon
Length (m)Sold by length
Max cable diameter (mm)11.0
2 reviews
Impeccable
C'est la deuxième fois que je prends cette gaine.
Bonne qualité et du plus bel effet.
Ces gaines donnent un effet très qualitatif aux cables.
This review has been posted for ELECAUDIO ADIACIUM GR Extensible PET braided sleeve Nylon 4-11mm
Durabilité, qualité, simplicité.
Bientôt 5 ans que cette gaine protège mes câble d'alimentation pour un amplificateur dans ma voiture, ainsi que mes câbles HP et RCA (dans dans dimensions plus resserrées)
La gaine est simple à mettre en place autour du câble, c'est même très satisfaisant à faire !
Ensuite je doit dire que la longévité sans faille ne me surprend pas vu la qualité perçue lors de la mise en œuvre, mais force est de constater qu'après 5 ans aucun signe de faiblesse. Les parties dont j'ai un accès visuel n'ont pas changé d'aspect notamment sous le capot moteur près de la batterie qui est un environnement plutôt engageant, la gaine traverse le temps sans aucun problème.
J'en suis évidement hyper content.
Merci Audiophonics de proposer du matériel d'une aussi belle qualité.
Braided sleeve made in  PET (Polyethylene Terephthalate)  mono-strands which can be used in a wide variety of applications....
