ELECAUDIO ADIACIUM GW Extensible PET braided sleeve Nylon 4-11mm
Braided sleeve made in PET (Polyethylene Terephthalate) mono-strands which can be used in a wide variety of applications.
Thanks to its expansibility, the unique PET weaving allows easy and fast installationon bulky connectors of irregular shape.
4.0 / 5
Reference : 11416
1,80 €tax incl.
1,50 € tax excl.
Shipping date: 15-04-2025.
Gaine vendue au mètre
The PET is braided from a 0.010 "monofilament of PolyEthylene Terephthalate for continuous use at temperatures between -40 ° C and 125 ° C .
Its melting temperature is 210 ° C . It has good dielectric qualities as well as excellent tensile strength and an good elasticity .
Its versatility is such that it is used in fields as varied as the automotive industry, computing, scuba diving, electronics, harnesses, audiovisual, and even some military applications.
This braided sheath was designed and manufactured in France .
Depending on the diameter of your cable, it is necessary to plan the reduction of the sheath length according to the following table:
SHEATH LENGTH ACCORDING TO CABLE DIAMETER
Cable diameterRequired sheath length
Ø4mm1m
Ø6mm1.08m
Ø8mm1.15m
Ø10mm1.3m
Ø12mm1.7m
Features :
  • For cable with diameter Ø between 4 and 11mm
  • Structure Polyethylene Terephthalate monofilament
  • High elasticity and excellent tensile strength
  • Temperature Resistance: -40 ° C to 125 ° C
  • Melting Temperature: 210 °
  • Color: Light gray / White
  • Sold by the meter
ColorGray
ColorWhite
MaterialNylon
Length (m)Sold by length
Max cable diameter (mm)11.0
2 reviews
Jolie gaine mais s'éffiloche
Tout est dans le titre, très belle gaine, facile à couper et à ajuster sur des câbles de modulation. toutefois elle s'effiloche sur toute la longueur.
Il faut la passer au briquet sur toute la surface pour les retirer. Et comme c'est une gaine claire, faire attention car elle peut noircir vite.
This review has been posted for ELECAUDIO ADIACIUM GW Extensible PET braided sleeve Nylon 4-11mm
Óptima funda con acabado elegante.
El material es excelente y da una buena sensación al tacto. Rápida de utilizar gracias a una buena expansibilidad. Utilizada para realizar dos cables de interconexión: acabándola con funda termo retractable el resultado es profesional. Muy satisfecho.
Braided sleeve made in  PET (Polyethylene Terephthalate)  mono-strands which can be used in a wide variety of applications....
