ELECAUDIO CU-07 Braided Sheath Extensible Copper PVC 06-10mm
Reference : 7530
2,50 €tax incl.
2,08 € tax excl.
ELECAUDIO PG-06 Braided Sheath Extensible (PVC) 06-10mm
Braided sleeve made in PVCwhich can be used in a wide variety of applications. Thanks to its expansibility and its unique braiding, it allows its simple and fast installation on bulky connectors of irregular shapes.
Its melting point is 160 ° C. It has good dielectric qualities as well as excellent tensile strength and good elasticity. Its versatility is that it is used in fields as varied as the automotive industry, computer science, scuba diving, electronics, harnesses, audiovisual, and even some military applications. bodytext ">colorCopper, 100% brilliant gold plating exclusive to ELECAUDIO brand.
ATTENTION: Depending on the diameter of the cable the effective length of the sleeve can reduce up to 20%!
Specifications:
  • For cable diameter between 06 and 10mm
  • Colors Brilliant copper
  • StructurePVCmonofilament
  • High elasticity and excellent tensile strength
  • Temperature Resistance: -40 ° C to 125 ° C
  • Melting Temperature: 160 °
https://www.audiophonics.fr/images2/4911_GAINE_ELECAUDIO_DARK-GREY_4.jpg
https://www.audiophonics.fr/images2/7530/7530_elecaudio_gaine_cuivre.png
https://www.audiophonics.fr/images2/7530/elecaudio_gainetresse_2.jpg
ColorCopper
MaterialPVC
Length (m)Sold by length
Max cable diameter (mm)10.0
Gaine cuivrée du plus bel effet ,facile à mettre en œuvre mais un peu fragile avec une tendance à s'effilocher.
This review has been posted for ELECAUDIO CU-07 Braided Sheath Extensible Copper PVC 06-10mm
