ELECAUDIO EB-05 Braided Sheath Extensible Nylon (PET) 07-14mm
Braided sheath made of PET (polyethylene terephthalate) monobrins which can be used in a wide variety of applications. Thanks to its expansion properties, PET's unique braiding makes it easy and quick to install on large, irregularly shaped connectors.
4.4 / 5
Reference : 4914
1,50 €tax incl.
1,25 € tax excl.
Shipping date: 22-04-2025.
Gaine vendue au mètre
Elecaudio EB-05
Braided sleeve nylon PET 7-14mm
elecaudio eb-05 gaine tressée nylon
PET is braided from 0.010" PolyEthylene Terephthalate monofilament for continuous use at temperatures between -40°C and 125°C. Its melting temperature is 210°C. It has good dielectric properties as well as excellent tensile strength and elasticity. Its versatility is that it is used in fields as varied as the automotive industry, computing, scuba diving, electronics, electrical harnesses, audiovisual, and even some military applications.
Electric Blue colour exclusive to the ELECAUDIO brand.
CAUTION: Depending on the cable diameter the effective length of the sheath can reduce up to 20%!
Depending on the diameter of your cable, it is necessary to plan the reduction of the sheath length according to the following table:
SHEATH LENGTH ACCORDING TO CABLE DIAMETER
Cable diameterRequired sheath length
Ø7mm1m
Ø8mm1.08m
Ø10mm1.15m
Ø12mm1.3m
Ø14mm1.7m
Acceptable cable diameter7 to 14mm
ColorElectric blue
MaterialPolyethylene Terephthalate single strand
High elasticity and tensile strength-
Temperatures-40°C to 125°C
Fusion temperature210°C
ColorBlue
MaterialNylon
Length (m)Sold by length
Max cable diameter (mm)14.0
7 reviews
Very good product
This skin is easy to work with and has very good appearance.
I used it on OYAIDE TUNAMI V2 Ø15mm cable and it fitted perfectly.
Excellent value for money!
This review has been posted for ELECAUDIO EB-05 Braided Sheath Extensible Nylon (PET) 07-14mm
Joli
Super finition avec cette gaine, délicat à couper faut avoir d'excellents ciseaux & finir avec de la gaine thermo rétractable
Gaine pas à la bonne taille
La gaine est vendue pour des cables entre 8 mm et 16 mm. J'ai acheté un cable de 16 mm mais la gaine est trop étroite. C'est regrettable de devoir la jeter...
Gaine Tressée Elecaudio
Rapport Q/P excellent , très belle aspect donnant une finition parfaite pour vos câbles !
pour une finition impeccable.
belle , extensible , robuste , j ai l impression d avoir un cable qui sort du magasin .
Plus que jamais faites vos câbles vous-même .
Braided sheath made of PET (polyethylene terephthalate) monobrins which can be used in a wide variety of applications. Thanks to its expansion...
