ELECAUDIO GB-05 Extensible PET braided sleeve Nylon 07-14mm
Braided sleeving made from single-strand PET (Polyethylene Terephthalate) that can be used in a wide variety of applications. Thanks to its expandability, the unique braiding of PET allows it to be installed quickly and easily on bulky and irregularly shaped connectors.
Reference : 4916
1,40 €tax incl.
1,17 € tax excl.
Shipping date: 22-04-2025.
Gaine vendue au mètre
ELECAUDIO GB-05
Nylon Expandable Braided Sleeving (PET) 07-14mm
The PET is braided from a 0.010'' monofilament of PolyEthylene Terephthalate for continuous use at temperatures between -40°C and 125°C. Its melting point is 210°C. It has good dielectric qualities as well as excellent tensile strength and good elasticity. Its versatility is that it is used in fields as varied as the automotive industry, computing, scuba diving, electronics, electrical harnesses, audiovisual, and even certain military applications.
"Gloomy Brown" color, subtle combination of brown, cream and black stripes, exclusive to the ELECAUDIO brand.
ATTENTION: Depending on the diameter of the cable the effective length of the sheath can be reduced by up to 20%!
Depending on the diameter of your cable, it is necessary to plan the reduction of the sheath length according to the following table:
SHEATH LENGTH ACCORDING TO CABLE DIAMETER
Cable diameterRequired sheath length
Ø7mm1m
Ø8mm1.08m
Ø10mm1.15m
Ø12mm1.3m
Ø14mm1.7m
Spécifications :
  • For cable diameter between 07 and 14mm
  • Exclusive "Gloomy Brown" colorway
  • Single strand Polyethylene Terephthalate structure
  • High elasticity and excellent tensile strength
  • Temperature resistance: -40°C and 125°C
  • Melting temperature: 210°
https://www.audiophonics.fr/images2/4911_GAINE_ELECAUDIO_DARK-GREY_4.jpg
ColorWhite
ColorBrown
MaterialNylon
Length (m)Sold by length
Max cable diameter (mm)14.0
3 reviews
Excellent! Gaine ELECAUDIO GB-05 Gaine Tressée Extensible Nylon (PET) 07-14mm
Novice, ma 1ere fabrication de câbles hifi en bi-amplification sur du diamètre 11 millimètres 'SPM440 Eléphant 4 x 4mm2'. Très facile à glisser. Prévoir de la perte. Excellent résultat final! Mon câble semble très robuste et cela fait très 'pro'. Très content de mon achat .
This review has been posted for ELECAUDIO GB-05 Extensible PET braided sleeve Nylon 07-14mm
Very happy
This sleeve is both beautiful and high quality. Will buy again.
Bien lire la description
Superbe rendu sur câble de 13mm.
Je confirme, la longueur finale dépend aussi du diamètre.
Commandé 2m, couverture 1,35m.
Prévoyez un bon 50cm sur grosse section.
Gilles.
Braided sleeving made from single-strand PET (Polyethylene Terephthalate) that can be used in a wide variety of applications. Thanks to its...
