ELECAUDIO NG-15 Sheath Braided Stretch Nylon (PET) 11-20mm
Braided sleeve of gray color elaborated in PET (Polyethylene Terephthalate) mono-strands which can be used in a wide variety of applications. Thanks to its expansibility, the unique PET braiding allows its simple and fast installation on bulky connectors of irregular shapes.
Reference : 7238
2,20 €tax incl.
1,83 € tax excl.
Shipping date: 22-04-2025.
Gaine vendue au mètre
ELECAUDIO NG-15
ThePETis braided from a 0.010 "mono filament of PolyEthylene Terephthalate for continuous use at temperatures between -40 ° C and 125 ° C. Its melting point is 210 ° C. It has good dielectric qualities as well as excellent tensile strength and good elasticity. Its versatility is that it is used in fields as varied as the automotive industry, computer science, scuba diving, electronics, harnesses, audiovisual, and even some military applications. The color "Charcoal Grey", combination of white fibers and metallic gray, is exclusive to the brand ELECAUDIO.
ATTENTION: Depending on the diameter of the cable the effective length of the sleeve can reduce up to 20%!
Depending on the diameter of your cable, it is necessary to plan the reduction of the sheath length according to the following table:
SHEATH LENGTH ACCORDING TO CABLE DIAMETER
Cable diameterRequired sheath length
Ø11mm1m
13mm1.08m
Ø15mm1.15m
Ø17mm1.3m
Ø19mm1.7m
Ø20mm2m
Specifications:
  • For cable with a diameter between 11 and 20 mm
  • Color: Gray Anthracite
  • Structure Polyethylene Terephthalate monofilament
  • High elasticity and excellent tensile strength
  • Temperature Resistance: -40 ° C to 125 ° C
  • Melting Temperature: 210 °
https://www.audiophonics.fr/images2/4911_GAINE_ELECAUDIO_DARK-GREY_4.jpg
https://www.audiophonics.fr/images2/7238/7238_GAINE_ELECAUDIO_GREY_1.jpg
https://www.audiophonics.fr/images2/7238/7238_GAINE_ELECAUDIO_GREY_2.jpg
https://www.audiophonics.fr/images2/7238/7238_GAINE_ELECAUDIO_GREY_3.jpg
ColorGray
MaterialNylon
Length (m)Sold by length
Max cable diameter (mm)20.0
5 reviews
Conforme et sans surprise
Première fois que j'achète ce type de produit et c'était exactement ce à quoi je m'attendais. La gaine semble de bonne qualité, à voir avec le temps. Pour le moment, A+ :-)
This review has been posted for ELECAUDIO NG-15 Sheath Braided Stretch Nylon (PET) 11-20mm
Jolie teinte et qualitatif
Costaud et jolie
Applique une belle finition à mon câble wm audio un peu de gaine thermopropulsé dessus pour finir propre car cela s’effiloche facilement
Attention pour 4m de câble prendre je pense au moins 5m si vous voulez bien recouvrir l’intégralité du câble.
Un peu galère à mettre en place mais je regrette pas mon choix.
Bon produit
Gaine assez esthétique et facile d'utilisation.
gaine cable alim
Parfait , aspect sympa ,correspond exactement à ceque je voulais + service rapide.Merci
Excellente gaine
Très satisfait du rendu et de la qualité de cette gaine. La couleur est sympa pour mon cable d'alimentation de ma barrette.
Braided sleeve of gray color elaborated in  PET (Polyethylene Terephthalate)  mono-strands which can be used in a wide variety...
