ELECAUDIO NR-10 Braided Sheath Extensible Nylon (PP) Red 07-15mm
Braided sleeve made of nylon and polyester fiber (PP) that can be used in a wide variety of applications. Thanks to its expansibility and its unique braiding, it allows its simple and fast installation on bulky connectors of irregular shapes.
Reference : 7237
1,40 €tax incl.
1,17 € tax excl.
Shipping date: 25-04-2025.
Gaine vendue au mètre
ELECAUDIO NR-10
Its melting point is 210 ° C. It has good dielectric qualities as well as excellent tensile strength and good elasticity. Its versatility is that it is used in fields as varied as the automotive industry, computer science, scuba diving, electronics, harnesses, audiovisual, and even some military applications.
The color "Red Bordeaux", combination of black and deep red, is exclusive to the ELECAUDIO brand.
ATTENTION: Depending on the diameter of the cable the effective length of the sleeve can reduce up to 20%!
Depending on the diameter of your cable, it is necessary to plan the reduction of the sheath length according to the following table:
SHEATH LENGTH ACCORDING TO CABLE DIAMETER
Cable diameterRequired sheath length
Ø7mm1m
Ø9mm1.08m
Ø11mm1.15m
Ø13mm1.3m
Ø15mm1.7m
Specifications:
  • For cable diameter between 07 and 15mm
  • color"Red Bordeaux"Exclusive
  • High elasticity and excellent tensile strength
  • Temperature Resistance: -40 ° C to 125 ° C
  • Melting Temperature: 210 °
https://www.audiophonics.fr/images2/4911_GAINE_ELECAUDIO_DARK-GREY_4.jpg
https://www.audiophonics.fr/images2/7237/7237_GAINE_ROUGE_BORDEAUX_1.jpg
https://www.audiophonics.fr/images2/7237/7237_GAINE_ROUGE_BORDEAUX_2.jpg
ColorRed
MaterialNylon
Length (m)Sold by length
Max cable diameter (mm)15.0
6 reviews
spiderman !!!
Tres jolie gaine et de bonne qualité. son rendue rappelle la combinaison de l' homme araignée.... a part le bleu...
This review has been posted for ELECAUDIO NR-10 Braided Sheath Extensible Nylon (PP) Red 07-15mm
Belle finition, mais attention à la mise ne place.
Je pensais que ce serait les soudures qui me poserait le plus de problème à la réalisation d'n bon câble phono, mais c'est bien la mise en place de cette gaine qui à été une vraie difficulté (pour moi novice du DIY en câble audio).
Mais la qualité de finition est à la hauteur du temps passé à enfiler les trois câble dans cette gaine.
Petit bémol toute fois, le début et la fin de la gaine partent en morceau, prévoir un mettre de plus pour être vraiment tranquille.
Jolie
Le tressage est beau, protège le câble et lui donne un bel aspect.
Passé sur un OLFLEX 110/10mm, impeccable. A glisser façon "fabrication saucisse": on la pousse sur le câble, on la pince avec le câble et on le fait glisser naturellement... et ainsi de suite.
Très bon produit
Produit de qualité, la gaine ne se défait pas toute seule dès qu'on la manipule, et même assez détendue conserve un beau serrage des fils et reste très dense et esthétique contrairement aux produits bas de gamme chinois. Attention à la longueur commandée qui est la longueur "au repos", plus on la dilate plus elle raccourci, ce qui est tout à fait logique, mais on n'y pense pas forcément à la commande ;)
Rien à dire
Conforme à la prestation.
Très joli fini.
Et comme tjrs, attention aux longueurs selon les diamètres de câbles
Braided sleeve made of nylon and polyester fiber (PP) that can be used in a wide variety of applications. Thanks to its expansibility and its...
