ELECAUDIO SG-03 Expandable Braided Sheath Nylon (PET) 6-11mm
Braided sleeving made from single-strand PET (Polyethylene Terephthalate) that can be used in a wide variety of applications. Thanks to its expandability, the unique braiding of PET allows it to be installed quickly and easily on bulky and irregularly shaped connectors.
4.9 / 5
Reference : 4913
1,40 €tax incl.
1,17 € tax excl.
Shipping date: 15-04-2025.
Gaine vendue au mètre
ELECAUDIO SG-03
Braided Expandable Nylon (PET) Sleeving 06-11mm
The PET is braided from a 0.010'' monofilament of PolyEthylene Terephthalate for continuous use at temperatures between -40°C and 125°C. Its melting point is 210°C. It has good dielectric qualities as well as excellent tensile strength and good elasticity. Its versatility is that it is used in fields as varied as the automotive industry, computing, scuba diving, electronics, electrical harnesses, audiovisual, and even certain military applications.
"Shady Graphite" color, subtle combination of black and graphite stripes, exclusive to the ELECAUDIO brand.
ATTENTION: Depending on the diameter of the cable the effective length of the sheath can be reduced by up to 20%!
Depending on the diameter of your cable, it is necessary to provide for the reduction in the length of the sheath according to the following table:
SHEATH LENGTH ACCORDING TO CABLE DIAMETER
Cable diameterRequired sheath length
Ø6mm1m
Ø8mm1.08m
Ø10mm1.15m
11mm1.25m
Spécifications :
  • Pour câble de diamètre compris entre 06 et 11mm
  • Coloris "Shady Graphite" Exclusif
  • Structure Polyéthylène Terephtalate monobrins
  • Grande élasticité et excellente résistance à la traction
  • Résistance en Température : -40°C et 125°C
  • Température de Fusion : 210°
https://www.audiophonics.fr/images2/4911_GAINE_ELECAUDIO_DARK-GREY_4.jpg
ColorGray
MaterialNylon
Length (m)Sold by length
Max cable diameter (mm)11.0
7 reviews
Parfait
La parfaite finition pour habiller un cable.
This review has been posted for ELECAUDIO SG-03 Expandable Braided Sheath Nylon (PET) 6-11mm
Très belle finition pour la réfection d'une paire de câble modulation
Correcte
Rapport Q/P correct
ok pour le prix mais...
acheté pour "gainer" un cable d'enceinte supra 2,5, il faut prendre son mal en patience pour 2 fois 6,5 mètres . mais enfin je n'ai plus ce bleu pas très beau sous les yeux, remplacé par le nylon noir et gris de cette gaine . par contre j'aimerai un tuyau car elle s'effiloche à chaque bout trop facilement donc si quelqu'un a un "truc" merci d'avance.....
Óptima funda con acabado elegante
El material es excelente y da una buena sensación al tacto. Rápida de utilizar gracias a una buena expansibilidad. Utilizada para realizar dos cables de interconexión: acabándola con funda termo retractable el resultado es profesional.
Braided sleeving made from single-strand PET (Polyethylene Terephthalate) that can be used in a wide variety of applications. Thanks to its...
