ELECAUDIO VIPERA GN Extensible PET braided sleeve Nylon (PET) 09-13mm
Here is ELECAUDIO's VIPERA GN braided sleeve, made of single-stranded PET (Polyethylene Terephthalate) and can be used in a wide variety of applications. Thanks to its expansibility, the unique PET braiding allows its simple and fast installation on bulky connectors of irregular shapes.
Reference : 11279
1,00 €tax incl.
0,83 € tax excl.
Shipping date: 08-04-2026.
Gaine vendue au mètre
ELECAUDIO VIPERA GN
The EPT is braided from a 0.010 "monofilament of PolyEthylene Terephthalate for continuous use at temperatures between -40 ° C and 125 ° C. Its melting point is 210 ° C. It has good dielectric qualities as well as excellent tensile strength and good elasticity. Its versatility is that it is used in fields as varied as the automotive industry, computer science, scuba diving, electronics, harnesses, audiovisual, and even some military applications.
WARNING:cation of the cable diameter the effective length of the sleeve can reduce up to 20%!
Depending on the diameter of your cable, it is necessary to plan the reduction of the sheath length according to the following table:
SHEATH LENGTH ACCORDING TO CABLE DIAMETER
Cable diameterRequired sheath length
Ø9mm1m
Ø11mm1.08m
Ø13mm1.15m
Features :
  • For cable diameter between 9 and 13mm
  • Colors "Gray" Exclusive
  • Structure Polyethylene Terephthalate single-stranded
  • High elasticity and excellent tensile strength
  • Temperature Resistance: -40 ° C to 125 ° C
  • Melting Temperature: 210 °
  • MADE IN FRANCE
  • Sold by the meter (1 quantity = 1 meter)
ColorGray
MaterialNylon
Length (m)Sold by length
Max cable diameter (mm)13.0
4 reviews
superbe gaine
cette gaine est d' une qualité remarquable . Elle ne s'effiloche que tres peu, solide, confortable et facile a travailler 20/20.
En plus elle est trezs jolie.
This review has been posted for ELECAUDIO VIPERA GN Extensible PET braided sleeve Nylon (PET) 09-13mm
Très bien
Facile à mettre en place, à ajuster, ne s'effiloche pas.
Bel aspect esthétique
Facile
Jolie gaine facile à poser.
Ne se coupe pas aisément, flexible et solide.
Prévoyais un bon ciseau pour le coupé et un briqué pour finir le travail, résiste suffisamment pour évité le cisaillement de vos câbles à l'intérieur et donne une bonne extension une fois étiré.
La rétractation et assez élevée et avec une bonne gaine thermique et des fiche serrantes correctes vos montages et la tenue de votre gaine n'aura rien à envié au offre pré-monté commerciales.
Here is ELECAUDIO's VIPERA GN braided sleeve, made of single-stranded PET (Polyethylene Terephthalate) and can be used in a wide variety of...
