Stretchy Sheath Extensible Nylon (PET) 10-18mm Black
This black braided sleeving made of PET (Polyethylene Terephtalate) single strand can be used for many applications.  Thanks to its expandability, the unique braiding of PET allows for easy and quick installation on large and irregularly shaped connectors and cables.
4.7 / 5
Reference : 2311
0,70 €tax incl.
0,58 € tax excl.
Shipping date: 24-04-2025.
Extensible sheath
Extensible Sheath Nylon (PET) 10-18mm Black
Gaine tressée extensible Nylon (PET) 15-25mm Noir
PET is braided from a 0.010" Polyethylene Terephthalate monofilament for continuous use at temperatures between -40°C and 125°C. Its melting temperature is 210°C. It has good dielectric properties as well as excellent mechanical strength and elasticity. Its versatility is such that it is used in fields as varied as the automotive industry, computers, scuba diving, electronics, electrical harnesses, audiovisual and even some military applications.
Depending on the diameter of the cable to be sheathed, the effective sheath length can be reduced by up to 30%. We therefore recommend that you order a sheath length at least 30% longer than the length of your cable.
SHEATH LENGTH DEPENDING ON CABLE DIAMETER (FOR 1M CABLE)
Cable diameterSheath length required
Ø10mm1m
Ø12mm1.08m
Ø14mm1.15m
Ø16mm1.3m
Ø18mm1.7m
Product typeBraided sheath
MaterialPolyethylene Terephtalate (PET)
Min/Max cable diameter10mm / 18mm
Temperature resistance-40°C / 125°C
Melting temperature210°C
QuantitySheath sold by the metre
MaterialNylon
Length (m)Sold by length
Max cable diameter (mm)18.0
6 reviews
Excellente gaine mais...
Lors d'une première commande, la gaine présentait de petits accros sur toute sa longueur. Lors d'une deuxième commande, la gaine était en parfait état. Fonctionne également très bien autour d'un câble de 8mm.
This review has been posted for Stretchy Sheath Extensible Nylon (PET) 10-18mm Black
Produit conforme à la description
tout est dans le titre ..!
Pas encore utilisé pour d'éventuelles réserves à l'utilisation
Parfait rapport qualité/prix
Il faut faire attention au point de vu effilochage. Je confirme la remarque: En fonction du diamètre du câble, la longueur de la gaine peut réduire jusqu'à 20%. D'abord enfiler le cable dans la gaine et ensuite couper à la longueur. Je l'ai utilisé pour du ELECAUDIO CS-331B. La gaine fait bel effet.
Excellent rapport qualité/prix
je confirme les avis des autres utilisateurs, gaine facile d'utilisation à compléter avec de la gaine thermo aux extrémités.
Taille petit
Bon rapport qualité prix mais fait plutôt 10-12mm maxi car à partir de 12mm on commence à voir au travers.
 (4)
This black braided sleeving made of PET (Polyethylene Terephtalate) single strand can be used for many applications.  Thanks to its...
