Extensible Braided Sheath Nylon (PET) 20-36mm Black
This black braided sleeving made of PET (Polyethylene Terephtalate) single strand can be used for many applications.  Thanks to its expandability, the unique braiding of PET allows for easy and quick installation on large and irregularly shaped connectors and cables.
Reference : 3188
1,00 €tax incl.
0,83 € tax excl.
Shipping date: 24-04-2025.
Gaine vendue au mètre
Extensible sheath
Extensible Sheath Nylon (PET) 20-36mm Black
Gaine tressée extensible Nylon (PET) 15-25mm Noir
PET is braided from a 0.010" Polyethylene Terephthalate monofilament for continuous use at temperatures between -40°C and 125°C. Its melting temperature is 210°C. It has good dielectric properties as well as excellent mechanical strength and elasticity. Its versatility is such that it is used in fields as varied as the automotive industry, computers, scuba diving, electronics, electrical harnesses, audiovisual and even some military applications.
Depending on the diameter of the cable to be sheathed, the effective sheath length can be reduced by up to 30%. We therefore recommend that you order a sheath length at least 30% longer than the length of your cable.
SHEATH LENGTH DEPENDING ON CABLE DIAMETER (FOR 1M CABLE)
Cable diameterSheath length required
Ø20mm1m
Ø22mm1.08m
Ø24mm1.15m
Ø26mm1.3m
Ø28mm1.7m
Ø30mm2m
Product typeBraided sheath
MaterialPolyethylene Terephtalate (PET)
Min/Max cable diameter20mm / 36mm
Temperature resistance-40°C / 125°C
Melting temperature210°C
QuantitySheath sold by the metre
MaterialNylon
Length (m)Sold by length
Max cable diameter (mm)36.0
7 reviews
Fidèle à la description
Je l'ai mise sur de longs câbles de haut-parleurs Linn K400, il ne sont pas rond mais oblong, env. 3cm/1.5cm , la gaine s'est très bien adaptée à la forme. C'est très brillant comme rendu, mais quand même beaucoup mieux que la gaine brute des K400. Mais pur plastique au toucher. Mettre des gants pour les appliquer au risque de se bruler...
This review has been posted for Extensible Braided Sheath Nylon (PET) 20-36mm Black
Bon rapport qualité prix
Tendance à s'effilocher beaucoup en bout des tresses.
Parfait pour esthétique et protection des conducteurs
Acheté pour réaliser un CS en Diy, cette gaine est d'un excellent rqp et donne un bel aspect fini a mon cable.
SUPER PRODUIT
Conforme au descriptif et à mes attentes.
Livraison rapide.
Très satisfait du produit et du site !
Produit au top
Super produit livré dans les délais.
Bravo.
Un effort sur les frais de livraison et ça serait le paradis !!! ;)
This black braided sleeving made of PET (Polyethylene Terephtalate) single strand can be used for many applications.  Thanks to its...
