Extensible Braided Sheath Nylon (PET) 6-12mm Black
This black braided sleeving made of PET (Polyethylene Terephtalate) single strand can be used for many applications.  Thanks to its expandability, the unique braiding of PET allows for easy and quick installation on large and irregularly shaped connectors and cables.
4.8 / 5
Reference : 2109
0,70 €tax incl.
0,58 € tax excl.
Shipping date: 23-04-2025.
Gaine vendue au mètre
Extensible sheath
Extensible Sheath Nylon (PET) 6-12mm Black
Gaine tressée extensible Nylon (PET) 15-25mm Noir
PET is braided from a 0.010" Polyethylene Terephthalate monofilament for continuous use at temperatures between -40°C and 125°C. Its melting temperature is 210°C. It has good dielectric properties as well as excellent mechanical strength and elasticity. Its versatility is such that it is used in fields as varied as the automotive industry, computers, scuba diving, electronics, electrical harnesses, audiovisual and even some military applications.
Depending on the diameter of the cable to be sheathed, the effective sheath length can be reduced by up to 30%. We therefore recommend that you order a sheath length at least 30% longer than the length of your cable.
SHEATH LENGTH DEPENDING ON CABLE DIAMETER (FOR 1M CABLE)
Cable diameterSheath length required
Ø6mm1m
Ø8mm1.08m
Ø10mm1.15m
Ø12mm1.3m
Product typeBraided sheath
MaterialPolyethylene Terephtalate (PET)
Min/Max cable diameter6mm / 12mm
Temperature resistance-40°C / 125°C
Melting temperature210°C
QuantitySheath sold by the metre
MaterialNylon
Length (m)Sold by length
Max cable diameter (mm)12.0
9 reviews
Trop court et trop serré
Gaine de qualité bien que plus serrée que prévu. En effet j'ai commandé 7m pour un câble de 9mm de diamètre et de 6m de long mais ça s'est avéré largement trop court. Donc ne pas hésiter à prendre au minimum 30% de plus contrairement aux recommandations Audiophonics.
This review has been posted for Extensible Braided Sheath Nylon (PET) 6-12mm Black
Finition très propre.
Utilisée pour recouvrir une tresse de blindage sur le câble secteur d'un téléviseur.
Parfait
Très bonne gaine, utilisé pour confection câble Modulation, belle esthétique finale.
Gaine 6-12
Parfait, très bon rapport qualité prix
Françis S.
Cache bien les cables H P bi - cablage .
This black braided sleeving made of PET (Polyethylene Terephtalate) single strand can be used for many applications.  Thanks to its...
