Heatshrink Braided Tubing 2:1 Ø12-14mm Black
This 12mm diameter heat-shrinkable Nylon braided sleeve gives your cables a clean finish. The 2:1 ratio of this sleeve means that when heated to between 80 and 120°C, the diameter will be divided by 2.
Reference : 19412
2,50 €tax incl.
2,08 € tax excl.
Shipping date: 15-04-2025.
Gaine vendue au mètre
Heatshrink braided tubing 2:1 Ø12-14mm Black
Heat-shrinkable braided sleeve : Front view
This 12mm diameter heatshrinkable Nylon braided sleeve gives your cables a clean finish. The 2:1 ratio of this sleeve means that when heated to between 80 and 120°C, the diameter will be divided by 2 (Ø12mm -> Ø6mm).
Product typeHeat-shrinkable sleeve
Diameter before shrinkØ12-14mm
Shrink ratio2:1
Diameter after shrnk120°C
Shrink start temperature80°C
Full shrink temperature120°C
Min-max temperature-50°C - 150°C
MaterialNylon
Polyolefin monofilament
LengthSold by meter
Diameter (mm)12.0
MaterialNylon
Length (m)Sold by length
Number of conductorsNC
Insulation materialNC
ShieldingNC
Max cable diameter (mm)14.0
Section (mm²)N/A
This 12mm diameter heat-shrinkable Nylon braided sleeve gives your cables a clean finish. The 2:1 ratio of this sleeve means that when heated to...
