This 20mm diameter heatshrinkable Nylon braided sleeve gives your cables a clean finish. The 2:1 ratio of this sleeve means that when heated to between 80 and 120°C, the diameter will be divided by 2 (Ø20mm -> Ø10mm).
Product type | Heat-shrinkable sleeve |
Diameter before shrink | 20mm |
Shrink ratio | 2:1 |
Diameter after shrink | 10mm |
Shrink start temperature | 80°C |
Full shrink temperature | 120°C |
Min-max temperature | -50°C - 150°C |
Material | Nylon Polyolefin monofilament |
Color | Black |
Length | Sold by meter |
Color | Black |
Diameter (mm) | 20.0 |
Material | Nylon |
Length (m) | Sold by length |
Number of conductors | NC |
Insulation material | NC |
Shielding | NC |
Max cable diameter (mm) | 20.0 |
Section (mm²) | N/A |
