Heatshrinkable Braided Tubing 2:1 8mm Black
This 8mm diameter heat-shrinkable Nylon braided sleeve gives your cables a clean finish. The 2:1 ratio of this sleeve means that when heated to between 80 and 120°C, the diameter will be divided by 2.
Reference : 19408
1,90 €tax incl.
1,58 € tax excl.
Shipping date: 16-04-2025.
Gaine vendue au mètre
Heatshrink braided tubing 2:1 8mm Black
Heat-shrinkable braided sleeve : Front view
This 8mm diameter heatshrink Nylon braided tubing gives your cables a clean finish. The 2:1 ratio of this sleeve means that when heated to between 80 and 120°C, the diameter will be divided by 2 (Ø8mm -> Ø4mm).
Product typeHeat-shrinkable sleeve
Diameter before shrink8mm
Shrink ratio2:1
Diameter after shrink4mm
Shrink start temperature80°C
Full shrink temperature120°C
Min-max temperature-50°C - 150°C
MaterialNylon
Polyolefin monofilament
LengthSold by meter
Diameter (mm)8.0
MaterialNylon
Length (m)Sold by length
Number of conductorsNC
Insulation materialNC
ShieldingNC
Max cable diameter (mm)8.0
Section (mm²)N/A
Heatshrink Braided Tubing 2:1 8mm Black
This 8mm diameter heat-shrinkable Nylon braided sleeve gives your cables a clean finish. The 2:1 ratio of this sleeve means that when heated to...
