Stretchy Sheath Extensible Nylon (PET) 30-50mm Black
This black braided sleeving made of PET (Polyethylene Terephtalate) single strand can be used for many applications.  Thanks to its expandability, the unique braiding of PET allows for easy and quick installation on large and irregularly shaped connectors and cables.
Reference : 4576
2,00 €tax incl.
1,67 € tax excl.
Shipping date: 22-04-2025.
Gaine vendue au mètre
Extensible sheath
Extensible Sheath Nylon (PET) 30-50mm Black
Gaine tressée extensible Nylon (PET) 15-25mm Noir
PET is braided from a 0.010" Polyethylene Terephthalate monofilament for continuous use at temperatures between -40°C and 125°C. Its melting temperature is 210°C. It has good dielectric properties as well as excellent mechanical strength and elasticity. Its versatility is such that it is used in fields as varied as the automotive industry, computers, scuba diving, electronics, electrical harnesses, audiovisual and even some military applications.
Depending on the diameter of the cable to be sheathed, the effective sheath length can be reduced by up to 30%. We therefore recommend that you order a sheath length at least 30% longer than the length of your cable.
SHEATH LENGTH DEPENDING ON CABLE DIAMETER (FOR 1M CABLE)
Cable diameterSheath length required
Ø30mm1m
Ø32mm1.08m
Ø34mm1.15m
Ø36mm1.3m
Ø38mm1.7m
Ø40mm2m
Product typeBraided sheath
MaterialPolyethylene Terephtalate (PET)
Min/Max cable diameter30mm / 50mm
Temperature resistance-40°C / 125°C
Melting temperature210°C
QuantitySheath sold by the metre
MaterialNylon
Length (m)Sold by length
Max cable diameter (mm)50.0
3 reviews
RAS comme d'habitude
Coutumier maintenant de cette gaine mécanico rétractable je n'ai jamais eu aucun soucis avec les plusieurs dizaines de mètres utilisés, elle fait très bien le job et permet facilement une belle finition résistante.
This review has been posted for Stretchy Sheath Extensible Nylon (PET) 30-50mm Black
Pas mal pour une simple gaine de protection
Facile d'utilisation et bonne qualité de protection générale, j'aurais aimé une bi colore mais ne semble pas exister dans ces dimensions.
Elle protège mes câbles secteurs réalisés sur la base de conducteurs Néotech acheté sur ce même fournisseur.
J'achète depuis de nombreuses années chez Audiophonics et je suis très satisfait de nos échanges et de leur rapidité d'exécution.
Gaine nylon
Très bonne qualité pour cette gaine en nylon, idéal pour vos câbles Hifi et autres. Merci
This black braided sleeving made of PET (Polyethylene Terephtalate) single strand can be used for many applications.  Thanks to its...
