Pour un câble de 1,90 m, j’ai commandé 2 mètres mais c’était trop juste… solution : j’ai dû réduire la taille du câble à 1,80m + gaine thermo et là c’est nickel !
The diameter of these ducts can be adjusted by 13-26mm.
It is possible to overlay 2 layers of braided sleeve, so your cable is even better protected.
Depending on the diameter of your cable, it is necessary to provide for the reduction in the length of the sheath according to the following table:
Sheath length required for cable diameter | |
Ø13mm | 1.05 |
Ø14mm | 1.08 |
Ø16mm | 1.10 |
Ø20mm | 1.30 |
Ø26mm | 1.80 |
Color | White |
Color | Gray |
Color | Blue |
Material | N/A |
Length (m) | Sold by length |
Max cable diameter (mm) | 26.0 |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
