ALLO USBRIDGE Aluminum - Audio Media player Volumio interface for USB DAC
This version of the ALLO Network Drive includes the VOLUMIO software pre-installed. It is thus the easiest version of use for neophytes.
Reference : 13489
189,00 €tax incl.
157,50 € tax excl.
ALLO USBRIDGE Aluminium Version
ALLO SPARKY + ALLO USBRIDGE + VOLUMIO
Allo USBRIDGE
This version of the ALLO USBRIDGE includes a ready-to-use solution with an ALLO SPARKY+ an ALLO USBRIDGE+ an Aluminium Case+ an ALLO Volumio version.
By its architecture in 3 pieces of an exemplary finish the aluminium box supplied with the bundle ALLO UBRIDGE ALLO SPARKY is the ideal tool of transport streamer HIFI. It serves as a natural heat sink and barrier against EMI waves in particular. it is particularly dedicated to a Hifi use offering a density and an insensitivity to mechanical vibrations.
Full integration with ALLO SPARKY and ALLO USBRIDGE
The ALLO aluminium bundle thus offers a turnkey solution with a stable high quality USB output without jitter harmful to use as a HIFI streamer server. A more explicit description of the qualities of this high precision USB module is available on this page: ALLOUSBRIDGE. Thus the ALLO Sparky and ALLO USBRIDGE set offers a high resolution module competing with AURALIC, SOTM, Linn or Aurender solutions. You can connect this set to a USB DAC with the highest possible USB transfer quality. (see screen below showing stable signal on USB output measured on Teledyne Lecroy system)
Integration with OS Volumio
software volumio
In order to complement this powerful solution, the ALLO SPARKY and ALLO USBRIDGE + aluminium case are supplied with the OS Volumio.
First class components
The module includes 6 Nichicon electrolytic capacitors 330µF 35V to ensure a constant power supply and high precision resistors for a very good signal-to-noise ratio.
This product is incompatible with the SMSL AD18 amplifier.
Power connectorJack DC 5.5/2.5mm
Dimensions100 x 65 x 45mm
Weight800g
Package1x Allo Sparky
1x Allo USBridge board
1x Aluminium case
Allo USBridge
Allo USBridge
InputMicro SD
OutputUSB
Max sampling rate192kHz
2 reviews
excellent
Ce lecteur réseau doté du logiciel Volumio est très facile à mettre en oeuvre, la recherche des disques de stockage (NAS ou usb) est quasi automatique. Je n'en dirai pas autant de la version Dietpi (je n'ai jamais réussi à connecter un disque de stockage, pas doué sans doute...). Pour ce qui est de la qualité de sortie USB de cet appareil, elle est remarquable, Si on veux en profiter pleinement il faut soigner l'alimentation tant du lecteur de ce qui est autour (disque de stockage usb par exemple qui génère beaucoup de bruit) . Donc douceur et transparence garanties sur un bon DAC usb ou une bonne interface spdif.
This review has been posted for ALLO USBRIDGE Aluminum - Audio Media player Volumio interface for USB DAC
Très bon
Couplé à l’alim ifi le rendu est excellent! pas mieux pour le prix : son plus clair et précis qu’avec foobar Asio sur le PC.
Mise en route de l’os Volumio accessible avec les infos à dispo sur le net; idem pour monter un répertoire du Nas et paramétrer un Dac.
