Great product. Works as expected. Excellent service.
The ALLO USB Bridge is a streamer player with a USB Bridge card and SBC ALLO Sparky. It transforms your USB DAC into a Squeezelite or Roon network drive with the best USB output on the market, allowing you to attack a USB DAC with the highest quality digital audio transfer.
USB interface
An ALLO SPARKY is not initially designed for high fidelity applications. Its voltage regulators and USB ports are noisy. The USB Allo USBridge interface lets you output a USB AUDIO Class 2 signal with no noise, great stability. Your DAC USB finally receives an ALLO SPARKY, the digital signal in its entirety, without jitter.
The Allo USBridge was therefore created to overcome all these problems. To do this, it uses two independent USB controllers on a proprietary clock, a chip that reformats the signal using high-quality NDK oscillators, powered by independent LDO controllers and high frequency filters. Thus, the harm distortionis attenuated to the maximum to perfectly restore your music.
The Allo USBridge is comparable to MicroRender Sound in its use, while carrying high-quality components.
The Allo USBridge comes with an Allo Sparky SBC (Single Board Computer), an eMMC 16Gb, a transparent acrylic case and the DietPi operating system, allowing you to mount a system that you can connect directly to your DAC. The USBridge does not need a driver, it is completely transparent with the software solution used.
Input | 1x GPIO for Allo Sparky |
Output | 1x USB |
Power supply | Via jack DC 5V 3A -5.5 / 2.5mm (AC power adapter included) |
Package | 1x Allo USBridge + 1x Allo Sparky + 1x eMMC 16Go + 1x acrylique Black Case |
Caution: This product contains only a USBridge interface, an SBC Sparky, an acrylic case and a DietPi OS. The SMSL AD18 and the DAC Audio-GD are not provided.
Software management
System options
System performance data
O!MPD Interface
Roon Interface
Average votes 4.4 / 5 5 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Dimitrios M.
jan willem d.
Philippe W.
François S.
