ALLO USBRIDGE SIGNATURE PLAYER Streamer USB Interface Ultra Low Noise + Case + Volumio
The Allo USBridge Signature Player is based on a Raspberry Pi Compute Module 3+ SBC (Single Board Computer), offering this system great versatility. The Volumio operating system is pre-installed and the streamer is delivered mounted in a custom-designed aluminum housing.
Reference : 14697
299,00 €tax incl.
249,17 € tax excl.
Allo USBridge Signature Player Lecteur Réseau Interface USB Ultra Faible Bruit + Boîtier
USBridge Signature
The Allo USBridge Signature Player is based on a Raspberry Pi Compute Module 3+ SBC (Single Board Computer), offering this system great versatility. The Volumio operating system is pre-installed, and will allow you to easily access your entire audio library on a network or locally (USB storage).
The purpose of this module is to reduce noise on the USB bus as much as possible in order to provide the purest, most accurate and richest sound reproduction possible. For this purpose, the USBridge Signature includes an excellent USB control chip from TI and the Ethernet circuit is completely separate from the USB circuit, thus limiting interference. In addition, noise has been reduced on each power rail through the use of more than 30 LDO controllers. Even the power rail of the Micro SD port has its own LDO. Thus, the module does not include any switching elements that can generate noise.
As the USBridge Signature is based on a Pi Compute, Allo has chosen to integrate all the available connectivity on a standard Raspberry Pi, namely a GPIO port, USB-A, HDMI and a Micro SD slot. Therefore, anything that works with a Raspberry Pi will work with the USBridge Signature.
Volumio, state-of-the-art audio software pre-installed
Volumio
Unlike many network players based on an SBC such as Raspberry Pi, this player is already equipped with pre-installed audio software. It is therefore not necessary to have any Linux installation or Micro SD card flashing skills. The device is ready to use, all that is left to do is to connect it to your network and enjoy its full range of capabilities.
Volumio is a software package developed to offer a high-performance interface from an audio point of view, while remaining as comfortable and intuitive to use as any consumer solution. This software exploits the full hardware capabilities of the Raspberry Pi Compute, in particular its connectivity, since it offers the possibility to control the player from any device capable of connecting to a web browser (computer, smartphone, tablet or even another SBC... etc.). It is therefore very simple to choose music, change playback options or the volume level from anywhere, as long as the network connection exists.
To go even further and extend the device's capabilities, Volumio is also able to manage a WiFi hotspot, i.e. to establish an ad hoc network if the fixed network fails. This means on the one hand that the device will still be able to play your audio library even if your router / box fails, and on the other hand that this network player can be moved to be used in private network locations (an advantage in combination with its small size).
Volumio
Review and presentation by The Hans Beekhuyzen Channel
Aluminium Case
This Aluminium case has been specially designed by Allo to cover the USBridge Signature, protecting it from dust and shocks. Tightly stretched, the housing allows access to all the USBridge Signature connectors.
The USBridge Allo is delivered mounted in the housing.
Product typeStreamer
SBCRaspberry Pi Compute Module 3+
OSVolumio
Inputs3x USB-A 2.0 Host
1x Gigabit Ethernet RJ45
1x Micro SD slot
Outputs1x USB-A (delivers up to 900mA)
1x HDMI
Supported sampling ratesPCM up to 768kHz
DSD up to DSD512 (DSD1024 theoretically possible)
Ethernet chipsetAX88179
Ethernet bandwidth330Mbs
USB protectionAll USB Host ports include built-in overload protection
Alimentation5V 3A via USB-C (sold separately)
Certification USBridge SignatureFCC, CE
Case materialAluminium
Dimensions125x154x55mm
Weight net600g
InputRJ45
InputMicro SD
OutputHDMI
DAC / ADC ChipNC
Max sampling rateDSD1024
Max sampling rateDSD512
Max sampling rate768kHz
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsSpotify Connect
Streaming services & Network protocolsQobuz
Streaming services & Network protocolsWeb radios
Streaming services & Network protocolsTidal Connect
6 reviews
Excellent
J’ai acheté l’Allo USBridge Sig, il y a un an et je l’utilise avec le DAC R2R Pegasus.
L’appareil m’a donné satisfaction, pendant quelque temps, avec Volumio et Moode.
Ensuite, je suis passé ensuite à GentooPlayer qui me ravi, surtout depuis l’introduction du protocole de streaming Diretta à cette distribution, en début d’année.
Après l’achat d’un HAT PI2AES, l’Allo USBridge était retombé en disgrâce, pendant quelque temps. Le son du HAT PI2AES avec un Raspberry 3 était plus raffiné. Il est resté plus raffiné que celui de l’Allo même après l’ajout d’une interface digitale Audio-GD DI-20HE à mon système.
Il y a quelques semaines, j’ai essayé d’améliorer le son de l’Allo en plaçant un régénérateur USB iFi iGalvanic 3.0 entre sa sortie et l’interface digitale. Et là, à ma grande surprise, le son de l’Allo s’est nettement amélioré. Il est à présent plus ample et supérieur à celui du PI2AES.
Comme quoi, il est possible d’améliorer les performances de cet appareil dont la sortie USB est dite « propre ».
L’Allo est redevenu à présent le streamer que je préfère et je l’utilise dans le dispositif suivant :
Allo USBridge Sig → USB → iFi iGalvanic 3.0 → USB → Audio-GD DI-20HE → I2S → DAC R2R Pegasus.
This review has been posted for ALLO USBRIDGE SIGNATURE PLAYER Streamer USB Interface Ultra Low Noise + Case + Volumio
Excellent appareil question son
Parfait soniquement pour moi (timbres, dynamique, scène sonore...) mais attention ! Même s'il est dit que l'appareil fonctionne tout de suite, il demande quand même un minimum de connaissance ou d'habitude de l'informatique. De plus, on n'est jamais à l'abri de bugs avec une machine à base de Raspberry, bugs qui ne viennent pas de l'appareil lui-même bien sûr.
Après avoir essayé Volumio, j'ai tenté MOODE et je suis resté avec.
Génial
Je poste rarement des avis, mais celui-ci mérite d'être lu.
Ce lecteur réseau est bien meilleur que n'importe quel PC sous LINUX: Daphile, Windows ou Mac ou autre que j'ai pu essayer. Le bruit de fond est en net recul, les instruments sont plus définis. Tout ça pour un prix très honnête.
Sur une installation à 20000€+...
USBridge Allo signature
Après plusieurs échanges avec un technicien d'Audiophonics, j'ai choisi ce lecteur. Je l'ai associé avec l'alimentation Shanti. Associé au dac je dois dire que ce lecteur est excellent. Le système sous Volumio est simple à faire fonctionner. J'ai recyclé un vieux smartphone en guise de télécommande. Le lecteur est relié directement à ma box via un cäble RJ45 Cat 7.
Well thought-out quality player!
I got the ALLO Signature to stream my High Res audio from Qobuz to my brand new Quloos Amp via USB. Great combo, works fine, sounds fantastic. I got the ALLO Nirvana power supply in addition to the player, a good investment since it provides even lower noise clean power to the player. With volumio operating system, the player is easy to use and to configure, but there are also alternatives you can use. I'm definitely convinced by the ALLO player, another great piece of equipment in the Audiophonis wide range of excellent products.
The Allo USBridge Signature Player is based on a Raspberry Pi Compute Module 3+ SBC (Single Board Computer), offering this system great...
