AUDIOPHONICS RASPDAC I-SABRE V4 Kit DIY Streamer Raspberry Pi 3 B+ & DAC
The Audiophonics RaspDAC is supplied as a complete kit, so you can mount your DIY network drive yourself. This model is based on a Raspberry Pi 3 B+ and DAC Audiophonics I-Sabre V4 ES9023 TCXO.
4.4 / 5
Reference : 11136
219,00 €tax incl.
182,50 € tax excl.
This product is delivered as a DIY kit to mount yourself.
We also offer the mounted version: RaspDAC Raspberry Pi 3B+ & DAC I-Sabre V4 .
Audiophonics I-Sabre V4 ES9023 and Raspberry Pi 3 B+ Network Player
RaspDAC
Reach high definition dematerialized with RaspDAC. Case 100% Aluminum, DAC ES9023 24bit 192Khz TCXO, and Raspberry 3 B+!
This is the most recent updated version, it benefits from the following upgrades :
  • Pre-made socket for infrared receptor
  • Micro-SD card slot
  • Version 3 B+ Raspberry Pi
  • I-Sabre 4th generation
Everything hardware-related is included and operationnal. The only prerequisite before playing music is deciding which software you like the most (Max2Play, piCorePLayer...) and installing the latter on RaspDAC
A high-end digital audio player ...
This evolution of our RaspDAC is now much faster thanks to the implementation of Raspberry Pi 3 B+, has a hole for an infrared receiver, and a micro SD card reader offset, when it was difficult to access to the first version.
OptAUDIOPHONICS integrates the famous DAC I-Sabre V4 24 / 192Khz equipped with a TCXO precision clock as well as a circuit of masses reviewed and corrected, and a low noise regulation LDO capacitors OS Con, this DAC I-Sabre V4 is the heart of the RaspDAC.
OfPlus, its advanced ATX power management with different possible shutdown modes offer a high level of ease of use.
It has all the inputs / outputs required for its connection, its(DC Jack 5.5 / 2.1mm), an HDMI port, a micro SD card port and an OLED display.
RaspDAC
Le software
Announcing itself as a free system, RaspDAC is delivered with without operating system installed . You are free to choose and install the one that best suits your needs. Some features require the installation of custom scripts to work if you do not choose a pre-installed image :
  • The power management functions use a Python script to install (or manual plugin available in Volumio).
  • The OLED screen works with a dedicated script that only works under Volumio and LMS (DietPi).
  • IR reception requires the installation of LIRC, the power management of its dedicated script.
  • The hardware volume requires the use of the dedicated driver (native in DietPi, manual plugin in Volumio).
Volumio
Currently we recommend using Volumio which offers both very good audio performance but also a simple, intuitive and above all accessible interface from any device connected via a web interface.
Volumio allows you to read from a NAS on the network, from a UPnP source or from a local storage such as a hard disk or USB key. It also provides access to web radios and has a Spotify plugin. It also manages the DLNA protocol allowing to control the player from an application like Bubble UPnP, which itself is able to read many streams and has a Qobuz plugin. The AirPlay is also managed.
Volumio
To make it a ready-to-use product and to be able to use the product as soon as it is received, we propose an SD card including a pre-configured Volumio image with the plugins necessary for the functions present on the RaspDAC. We strongly recommend it to beginners. Indeed, the installation and configuration of this type of solution requires a good knowledge of Linux and the hardware used.
Buy Volumio SD Card
Vous pouvez cependant opter pour d'autres solutions comme par exemple Max2Play et son interface soignée et sa compatibilité ou encore DietPi et sa grande modularité.
Max2Play
DietPi
Discover and download RaspDAC Image
Your Raspberry Pi 3 B+ in a high quality Audio environment.
It has been designed with the aim of allowing you to have the effectiveness of your Raspberry Pi 3 B+ in a high quality Audio environment. Especially elegant and discreet, it offers you the possibility to have a powerful audio solution and achieved an unbeatable value for money.
Raspberry Pi 3Model B+
DACI-Sabre V4 ES9023 TCXO
displayOLED
Inputs1x RJ45 / 4x USA-A / 1x Micro-SD Port
Outputs1x RCA Stereo
Power SupplyJack DC 5.5 / 2.1mm
Dimensions160 x 140 x 50mm
Display Size65 x 16mm
Weight0.9kg
Housing material100% Aluminum
Aluminum Case for I-Sabre DAC V4 & Raspberry Pi 2 / 3 / 3 B+
This 100% Aluminum case is designed to accommodate the Raspberry Pi 2/3/3B+ & Audiophonics DAC I-Sabre V4 ES9023.
RaspDAC housing
The kit contains:
  • 1x Aluminum housing for I-Sabre DAC
  • 1x DAC Audiophonics I-Sabre V4 ES9023 TCXO
  • 1x Raspberry Pi 3 Model B+
  • 1x Winstar OLED 16x2 Screen White HD44780
  • 1x Pushbutton Aluminum with pre-welded wires
  • 1x HDMI Male to HDMI Partition Wall
  • 1x 1GB Sandisk 8GB Micro SD Memory Card
  • 1x Tablecloth interconnect with dual XHP 2.54mm 6PIN
  • 1x power adapter 7V 3A
DAC / ADC ChipES9023
Max sampling rate192kHz
9 reviews
Grand problème de fiabilité
Je me vois contraint de revoir mon avis à la baisse : Les composants (l'écran dans mon cas) semblent présenter un gros problème de fiabilité.
Le premier a eu de légers problèmes d'affichage quasiment dès le début, et a lâché au bout de moins d'1 an et demi.
Il a été changé et l'autre n'a tenu que 4 mois !! Je suis vraiment déçu...
POur ma part, ce genre d'appareil est inutilisable sans écran : le téléphone ne propose que le titre et le temps écoulé (quand il n' y a pas d e décalage, ce qui arrive souvent...)
Les informations de l'écran sont quant à elles largement insuffisantes : Juste le temps écoulé de la piste en cours, pas de temps restant, et aucune indication des temps en cours et écoulé de la liste de lecture en cours.
En plus nous sommes tributaire de l'affichage, que l'on ne peut modifier comme on veut avec une télécommande...
Venant de la Hifi, avec des lecteur de CD vieux de 20 et 30 ans qui fonctionnent encore avec un affichage digne de ce nom, je suis vraiment déçu....
Certes le son est bon, mais l'interface est très perfectible et la fiabilité aléatoire...
Cela gâche beaucoup le plaisir et l'agrément d'utilisation (sans parler des bogues de l'interface...
Bref, j'i u écran de rab chez moi, que je vais devoir renvoyer, racheter des connecteur (l'écran est vendu sans) et attendre l'aller retour par la poste et le pire, devoir remettre les mains dans le cambouis et manipuler des vis lilliputiennes qui n’arrêtent pas de vous échapper des doigts...
This review has been posted for AUDIOPHONICS RASPDAC I-SABRE V4 Kit DIY Streamer Raspberry Pi 3 B+ & DAC
Lecteur réseau fonctionnel d'un bon RPQ
Avec la vidéo Youtube, on s'en sort, mais faut trouver des astuces pour installer le bouton d'allumage et le passage de la nappe.
Les connexions de la même nappe n'est pas si évidente et je l'ai fait un petit peu au flanc.
J'ai choisi Volumio comme OS et je pensais bien faire en commandant la version pré-configurée proposée, mais en réalité elle est destinée à la version "Mini" du RASPDAC et j'ai donc du avec le conseil d'Audiophonics télécharger l'image compatible. La carte "vierge" SD fournie dans le kit est pré-formatée et il est nécessaire de supprimer la partition avant d'y transférer l'image de Volumio. Une fois tout cela effectué, le système fonctionne très bien et j'y ai adjoint un ampli Audiophonics K214 du même format, ce qui fait un petit combo bien sympathique.
Je choisis une notation de 4 étoiles, pour tenir compte de quelques manques d'informations de montage.
Good product. Excellent service
Very happy with my RaspDac. It has a nice warm sound.
The DIY-kit is very easy to assemble (30 minutes) using the instruction video. I am currently using Volumio software. Works very intuitively with their setup 'hotspot' and model driven configuration pages. "easypeezie"
I was unlucky to have the power-supply mal-functioning after 2 days. Just bad luck. Audiophonics immediately took action and sent me a new power-supply. This is excellent service!
Thank you very much!
Mon premier lecteur réseau
Bonjour
Pour résumer, je suis très satisfait de mon achat.
Tout d'abord, je tiens à remercier toute l'équipe Audiophonics, qui est à l'écoute des clients, que ce soit avant ou après l'achat :
Avant, je me posais des questions sur la liaison wifi/ethernet, j'ai eu des réponses par mail et sur le forum
Après, mon écran a laché au bout d'une semaine ; Après l'envoi de quelques photos, Audiophonics m'en a expédié un gratuitement très rapidement !
MERCI !
L'appareil est élégant, bien conçu est solide.
Il fait le job très bien au vu de son prix.
Même si c'est mon 1er lecteur réseau, je le recommande chaudement pour faire ses premiers pas dans le dématérialisé !
J'ai acheté l'appareil en kit ; Informaticien construisant les PC de A à Z aussi bien de point de vue Hardware que Software depuis plus de 20 ans, je pensais que cela serait plutôt facile et rapide, ce ne fut pas tout à fait le cas :
- MONTAGE :
A voir la vidéo, je pensais en avoir pour 1/2 heure ; J'ai mis 2h 1/2 !
- les vis pour le montage de l'écran sont très petites, pas facile à manipuler et l'on doit s'y reprendre à plusieurs fois.
- Regarder au dos pour avoir le bon sens haut/bas, sinon on doit recommencer...
- une fois le bouton poussoir monté, l'ensemble RASP + DAC ne rentre plus, il faut desserer le bouton, monter l'ensemble et resserer après le bouton poussoir qui rentre juste entre Rasp et le DAC...
- Attention, lors de la fixation du RASP au boitier, à bien mettre les rondelles à l'extérieur, sinon la prise du bloc d'alimentation ne rentre pas suffisament et pas de place à l'intérieur pour que tout tienne.
- Les trous pour le HDMI sont trop rapprochés sur le boitier : Il faut visser les 2 vis de biais et avec du mal on arrive à faire tenir le tout.
- Pour la nappe du lecteur micro SD, il faut la repositionner au mieux une fois le tout monté, pour qu'elle ne soit ni compressée ni tordue...
- SOFT :
Etant sous Windows XP, l'utilitaire de création d'image (pour win XP) n'a jamais fonctionné...
J'ai du utiliser une vieux disque dur avec un Windows 10 que j'avais installé pour mettre à jour mon GPS avant les vacances...
- Les images de volumio non dédiées Audiophonics n'ont jamais réussi à s'exécuter sur l'appareil.
- Celle d'Audiophonics marche bien, mais quelle lenteur pour la télécharger : Après des heures et 2 ou 3 téléchargements interrompus, j'ai enfin réussi le lendemain matin de bonne heure :)
- VOLUMIO :
C'est gratuit et ça fait le job
- Pas très ergonomique pour faire les playlist : impossible de changer l'ordre ?, compliqué d'ajouter ou de supprimer une piste (menu contextuel)
- Pour sauvegarder vos playlist, si vous avez un NAS Synology, il faut brancher la carte Micro SD via un adaptateur sur l'USB du NAS : On a ensuite accès à 2 partitions. Dans l'une, prendre le chemin Dyn/Data/Playlist/ et vous pouvez copier/coller sur le Disque dur du NAS.
- On a aussi des web radios, c'est plutôt sympa.
J'utilise aussi l'interface web sur mon smartphone ; peut-être l'application est elle plus ergonomique ??
Voilà, j'espère que mon expérience en aidera certains :)
Patrick
Very nice dac
The kit is complete and easy to assemble, for this reason there are no instructions.
The audio quality is very good for the price.
I rewrote the python driver for the 16x2 LCD, link for download:
https://volumio.org/forum/audiophonics-sabre-pulsante-display-t6070-20.html
Bye
The Audiophonics RaspDAC is supplied as a complete kit, so you can mount your DIY network drive yourself. This model is based on a Raspberry Pi 3...
