AUDIOPHONICS RASPDAC I-SABRE V4 Streamer Raspberry Pi & DAC TCXO
The RaspDAC is a network player based on a Raspberry Pi 3 B+. With its display, it will allow you to enjoy simply your high definition dematerialized music. It is proposed in its version with DAC ES9023.
By buying this product you get 26 loyalty points
Reference : 11135
269,00 €tax incl.
224,17 € tax excl.
Audiophonics I-Sabre V4 ES9023 and Raspberry Pi 3 B+ Network Player
RaspDAC
Reach high definition dematerialized with RaspDAC. Case 100% Aluminum, DAC ES9023 24bit 192Khz TCXO, and Raspberry 3 B+!
This is the most recent updated version, it benefits from the following upgrades :
  • Pre-made socket for infrared receptor
  • Micro-SD card slot
  • Version 3 B+ Raspberry Pi
  • I-Sabre 4th generation
Everything hardware-related is included and operationnal. The only prerequisite before playing music is deciding which software you like the most and installing the latter on RaspDAC
Volumio Software is an ideal solution. Simple and easy to install with a very intuitive interface and with its high-quality restitution of sound. It can be controled from a web interface and will be a perfect match for your raspDAC.
All drivers are accessible from the download part of this webpage
logo volumio
A high-end digital audio player ...
This evolution of our RaspDAC is now much faster thanks to the implementation of Raspberry Pi 3 B+, has a hole for an infrared receiver, and a micro SD card reader offset, when it was difficult to access to the first version.
AUDIOPHONICS integrates the famous DAC I-Sabre V3 ES9023 24 / 192Khz equipped with a TCXO precision clock as well as a circuit of masses reviewed and corrected, and a low noise regulation LDO capacitors OS Con, this DAC I-Sabre V4 is the heart of the RaspDAC.
OfPlus, its advanced ATX power management with different possible shutdown modes offer a high level of ease of use.
It has all the inputs / outputs required for its connection, its(DC Jack 5.5 / 2.1mm), an HDMI port, a micro SD card port and an OLED display.
RaspDAC
Your Raspberry Pi 3 B+ in a high quality Audio environment.
It has been designed with the aim of allowing you to have the effectiveness of your Raspberry Pi in a high quality Audio environment. Especially elegant and discreet, it offers you the possibility to have a powerful audio solution and achieved an unbeatable value for money.
Raspberry Pi 3 Model B+
DACI-Sabre V4 ES9023 TCXO
displayOLED
<inputs/ Td>1x RJ45 / 4x USA-A / 1x Micro-SD Port
Output1x RCA Stereo
Power SupplyJack DC 5.5 / 2.1mm
Dimensions160 x 140 x 50mm
Display Size65 x 16mm
Weight0.9kg
Housing material100% Aluminum
Aluminum Case for I-Sabre DAC V4 & Raspberry Pi 2 / 3 / 3 B+
This 100% Aluminum case is designed to accommodate the Raspberry Pi 2/3 & Audiophonics DAC I-Sabre V4 ES9023.
RaspDAC housing
Supplied accessories:
To enable you to be directly operational, the player comes with an 8GB SDHC card, and its 7-9V / 2A power adapter.
Color
  • Black
Input
  • Micro SD
  • USB
Output
  • RCA
DAC / ADC Chip
  • ES9023
Max sampling rate
  • 192kHz
The RaspDAC is a network player based on a Raspberry Pi 3 B+. With its display, it will allow you to enjoy simply your high definition...
