AUDIOPHONICS RASPDAC LTE I-SABRE ES9038Q2M Streamer Raspberry Pi 3 B+ & DAC 32 bit
The RaspDac LTE family is enriched with a new version, this time integrating the ES9038Q2M 32bit decoding chip from ESS.
4.8 / 5
By buying this product you get 28 loyalty points
Reference : 13100
289,00 €tax incl.
240,83 € tax excl.
Audiophonics RaspDAC LTE I-SABRE ES9038Q2M
Network drive Audiophonics DAC ES9038 and Raspberry Pi 3 B+
Inside raspdac 9038Q2M map raspberry pi
The RaspDac LTE family is pround to present its new member, this time incorporating the decoding chip 32bit ES9038Q2M. A supercharged card for advanced audio performance at a very contained price. Take the opportunity to update your system to high definition player!
As far as hardware and electronic are concerned, the network drive is already ready for use. You just need to decide which audio player software to intstall  (Volumio, Max2Play, OSMC, piCorePlayer ...) or purchase a SD card containing an operating system to enjoy a  immeditae complete device. The device supports several different reading software, each offering a unique approach to playback (technical oriented, customizable or simple and intuitive otherwise).
Music Player Premium
hifi audio player raspberry pi
Get very simply a dematerialized audio player upscale resolution 32bit / 384kHz. The ES9038Q2M card is also capable of decoding up DSD128 natively.
The ATX type power management with advanced modes of possible shutting down provide a high level of comfort, in the utmost respect of hardware constraints, which also increases the lifespan of the equipment.
Optimized for the sole purpose to provide maximum music Audiophonics incorporates the new DAC ES9038 32 / 384kHz decoding equipped with the latest technology, automatic detection of different rates of samplings, hardware volume control, distortion and a Noise threshold impressive sound. All of which allow this Raspberry player to compete with extremely costly traditional solutions.
Your Raspberry Pi 3 B+ into a high quality audio environment.
Rear view connectors raspbery ft SABRE 9038
It was thought in order to allow you to have the effectiveness of your Raspberry Pi 3 B+ into a high quality audio environment. Particularly elegant and discreet, it offers you the possibility to have a powerful Audio and complete solution at an excellent value.
Case Aluminum DAC Audiophonics & 3 Raspberry Pi B +
This 100% Aluminum housing designed in our workshop receives the couple Raspberry Pi 3 B+ & DAC ES9038 Audiophonics I-Sabre.
It effectively protects against interference, some of the vibrations and promotes efficient heat dissipation.
Vibration aluminum housing audiphile
Regulated Linear power supply for raspdac
Compatible with regulated linear power supply
While a fully-functionnal power supply is already provided,  the RaspDac LTE's performance may still be significantly improved with an audio-dedicated power-supply.
To get the best possible sound of the player (background Decline and growth dynamics), we developed this linear regulated power supply specially designed for this type of device.
Characteristics
TypeNetwork Player
Raspberry Pi Version3 B+
DACES9038Q2M
Supported audio types384kHz / 32bit
PCM 16/24/32Bit Auto Switch
DSD 64/128
THD0.002dB
THD+N-108dB measured
Output Level1.54Vrms / 2.24Vpp
Inputs4x USB-A
1x RJ45 (Ethernet)
1x HDMI
1x Carte SD
ExitsRCA Stereo
Dimensions102x 168x 58mm
HousingAluminum
Weight630g
Power supplt7.5V 2.9A (supplied)
Input
  • Bluetooth
  • Micro SD
  • USB
Output
  • HDMI
  • RCA
Color
  • Black
DAC / ADC Chip
  • ES9038Q2M
Max sampling rate
  • 384kHz
Streaming services & Network protocols
  • AirPlay
  • DLNA
  • Qobuz
  • Spotify
  • Spotify Connect
  • Tidal
  • Tidal Connect
  • Web radios
9 reviews
fait très bien le job mais pas pour qui veut du clef en main
Peut faire penser à du gadget ou du chinois car très léger et l'alimentation mériterait d'être beaucoup mieux, mais c'est de la qualité. Galère pour le mise en oeuvre si on ne sait pas utiliser de logiciel de formatage de carte mémoire, je n'ai pas choisi l'option d'avoir une carte pré-installée par l'équipe d'audiophonics. Une fois installé, il faut bien paramétré le logiciel interne pour ses besoins, ça peut lire du DSD à la qualité maximale sans aucun problème (testé avec des fichiers officiels trouvés sur une plateforme officielle, qualité mp3 jusqu'au DSD maximal dispo sur le marché). Pris pour faire de la lecture streaming Spotify. J'utilise le plugin de streaming, pas l'application Spotify que l'on peut installer sur le DAC (il me semble que ça nécessite obligatoirement un compte payant Spotify, et je vous le recommande ne serait-ce que pour arrêter les pubs qui au final vous force la main à l'achat ou vous force à quitter l'expérience Spotify tellement c'est chiant et sans contrôle du volume sonore de la pub), je parle bien du plugin de streaming qui récupère la lecture de votre ordi/tablette/téléphone via le site ou l'application officielle Spotify. Ca fonctionne bien mais à la longue ça devient chiant de toujours devoir piloter l'appareil via les boutons volume de l'ordi/tablette/téléphone. Et c'est peut-être son point faible. Tout se fait par l'interface web ou par application mobile. De la configuration de l'appareil à la navigation musicale. Il n'y a pas de bouton physique autre que le power. Du coup, il n'y a pas ce petit plaisir de tourner le bouton de volume quand une musique favorite arrive, c'est con comme feeling mais ça fait toujours son effet. A refaire, j'irai directement vers du matériel clef en main, c'est plus cher mais c'est du plug and play ! Ne pas oublier de mettre à jour le logiciel interne et surtout de toujours le faire avec les sources de audiophonics. Je mets 2 étoiles parce que j'ai eu beaucoup de galères pour installer le logiciel, beaucoup de galère avec la fonction auto-power off, peut-être que le dac peut être plus performant mais pas envi de retourner dans la config au petits oignons. Je rajoute 1 étoile pour le service et les conseils de l'équipe audiophonics, ils répondent vite et à toutes vos questions. Au final je suis déçu de cet équipement, très difficile à vendre d'occasion, il est là, il est enfin configuré à minima, donc il restera pendant un certain jusqu'à son remplaçant.
This review has been posted for AUDIOPHONICS RASPDAC LTE I-SABRE ES9038Q2M Streamer Raspberry Pi 3 B+ & DAC 32 bit
Parfait
Content de mon achat, beau boitier en aluminium, son très bon et choix de l'OS, j'hésite maintenant à l'optimiser avec une alimentation optimisée.
LA solution parfaite pour un lecteur réseau évolutif
La qualité audio est remarquable. Mon lecteur CD Denon, pourtant très qualitatif à l'époque, fait désormais bien pâle figure lorsque l'on compare le rendu d'un CD et celui de sa version dématérialisée (via ExactAudioCopy). La précision des voix et des instruments, l'étagement des plans et la spatialisation des sources sonores, l'absence totale de souffle dans les passages de faible intensité sonore sont exceptionnels.
Mon lecteur de CD dispose d'une sortie SPDIF coaxiale pour y raccorder un DAC externe et il est vraiment dommage qu'Audiophonics n'ait pas équipé son lecteur d'une entré SPDIF (comme pour le RaspDAC Mini), d'autant que la carte DAC conçue par Audiophonics dispose d'une embase SPDIF IN. Ce raccordement en face arrière serait d'une grande utilité puisque comme beaucoup, je ne dématérialiserai pas la totalité de mes CD. C'est d'autant plus regrettable que le driver de la carte, désormais supporté nativement par le noyau Rapsberry OS, permet de sélectionner l'entrée SPDIF (ainsi que de contrôler matériellement le volume et de sélectionner l'un des 7 filtres de reconstruction prédéfinis de l'ES9038). Il est en outre complètement exploité par Moode Audio que j'ai installé après avoir examiné plusieurs autres solutions. Audiophonics devrait proposer une option ou un kit pour sa carte DAC incluant une embase SDPIF de même esthétique que les embases RCA ainsi qu'un connecteur pour le PCB avec la dizaine de centimètres de câble nécessaire.
La carte DAC est une mise à jour de la version décrite sur le site. Certains composants ont été miniaturisés (microcontrôleur Nuvoton), d'autres ont disparu (convertisseur Mornsun). L'espace gagné a permis l'installation d'un relais qui désactive les sorties audio en l'absence de signal. L'étage d'alimentation a été largement revu sans qu'il soit possible d'identifier certains composants nouvellement utilisés (dont le convertisseur DC/DC).
L'absence d'écran, de télécommande IR et autres périphériques spécifiques (dont l'utilité est en fait assez contestable pour un lecteur réseau piloté par une interface web déportée) est ici un vrai atout puisqu'il est possible d'installer les dernières versions des logiciels de lecture sans devoir les adapter à ces matériels à chaque nouvelle release. Le boitier intègre en revanche une carte d'alimentation "ATX like" qui permet d'allumer ou d'éteindre le matériel par l'appui du bouton en face avant (comme pour tous les autres matériels audio), ou de l'arrêter/le redémarrer par logiciel. Ce dispositif est indispensable pour couper proprement l'alimentation sans risque de corruption du système ou de la carte SD. Les scripts d'initialisation, d'arrêt ou de rédémarrage et quelques indications sont disponibles sur github via le site d'Audiophonics mais ils mériteraient d'être mis à jour (cf. utilisation d'un overlay pour la prise en compte du bouton poussoir par exemple) et accompagnés d'un vrai tutoriel.
Si l'on considère son prix, cette offre d'Audiophonics est vraiment compétitive. Pour ce qui est du délai, je me suis inquiété de l'attente d'un mois annoncée à la commande puisque le produit et certains de ses composants n'étaient pas disponibles, mais à tort : le lecteur est arrivé en temps et en heure.
Amazing Streamer DAC combo
I've comparing between Allo setup and Volumio Primo. I am glad I blind folded myself and gave RaspDac LTE a try. I-Sabor ES9038Q2M is no shame (Thanks to Audio Science Review). The chip is not all there is to it. Thanks to AudioPhonics, the separated power supply fixed Raspberry Pi 3B+'s shortcomings. The noise level is impressively low.
Sound quality is great although sound stage is not as full as my Schiit modi 3 + Vali 2 combination. However, the sound quality is high in crisp, accurate, and crystal clarity.
The Volumio setup is not been very kind. At boot up Volumio would recognize I-Saber ES9038Q2M but you won't get any sound. You need to first turns off D2I setting and reboot. After reboot the driver again won't recognize correctly. You need to ignore "Output Device" first, but manually choose DAC to ES9028Q2M, then reboot again. I am sure this is not faults of AudioPhonics. It's more of the Volumio software bugs.
Incroyable et excellente solution autonome
Je cherchais une solution numérique sans tous les soucis de dérive, d'ordi à entretenir, de réseau wifi instables etc ...
Là c'est parfait, la solution Volumio est très carrée, pas une seule anicroche; lecture réseau d'un NAS ou USB tout passe bien. Je pensais aller sur un gros NAS mais à l'usage il est beaucoup plus simple et efficace d'attacher un ou plusieurs disques USB et d'avoir une solution toujours prête à l'emploi.
Et le son, le meilleur DAC que j'ai écouté jusqu'à présent. Stabilité et clarté, pas de fatigue. Du Jazz à la techno tout y gagne encore, sur les voix et instruments à vent c'est fantastique de présence.
Merci Audiophonics
 (3)
