AUDIOPHONICS RASPDAC LTE ST4000 Streamer Raspberry Pi 3 B+ & DAC ES9018K2M
By buying this product you get 25 loyalty points
Reference : 11974
259,00 €tax incl.
215,83 € tax excl.
AUDIOPHONICS RASPDAC LTE V2 ST4000
Sabre ES9018K2M & Raspberry Pi 3 B+
RaspDAC LTE V2 ST4000 ES9018K2M
Le Raspdac LTE V2+ Raspberry Pi 3 B+ revient dans une toute nouvelle version équipée d'un convertisseur ST4000
Dematerialized at your fingertips
Switch to high definition dematerialized with RaspDAC LTE. Aluminum and Plexiglas case, DAC ST4000 32bit / 384kHz TCXO, Raspberry 3 B+ ! It is an affordable paperless reading solution assembled and tested in our workshops in France. Complete network player and ready to use electronically, all you have to do is opt for the software solution of your choice (piCorePlayer, Max2Play, Openelec ...).
max2play
piCorePlayer
A high-end audio player thanks to the DAC Sabre ST4000 ES9018K2M
Thanks to the ST90 ES9018K2M LAC you get a high-end digital audio player, accepting resolutions up to 32bit / 384kHz.
Optimized to offer a dynamic and accurate sound reproduction, this DAC ST4000 is equipped with a precision clock TCXO 100MHz Ultra low jitter. Assuring a THD + N (Harmonic Distortion + Noise) of 120dB and a S / N (Signal / Noise Ratio) of 127dB, this system offers excellent sound performance.
In addition, the interface between the Raspberry Pi 3 B+ and the DAC is here directly via an HDMI port. Thus, no need to install drivers to drive the DAC via the Raspberry.
Finally, the system offers a complete connectivity: 4 USB 2.0 ports to connect the devices of your choice (USB key, hard drive ...), 1 Ethernet port to enjoy the files stored on your network, a micro SD port for the OS, an HDMI output and a gold plated RCA output as well as a 3.5mm jack output to connect your favorite audio devices. So you have a complete panel of connectors to meet all your needs and can enjoy new possibilities of integration into your audio systems.
Raspberry Pi
Version 3 Model B+
Audiophonics DAC
ST4000 ES9018K2M TCXO
Design
Exclusive
Universal compatibility
Unlike our other streamers, this version uses an HDMI digital stream extraction technology. By avoiding the I2S and the necessity of compatible driver this solution allows you to have an audiophile decoding quality whatever the system used.
Design and reliable
Specially designed to allow you to have the efficiency of your Raspberry Pi 3 B+ in a high quality audio environment, it turns out to be as elegant and discreet so that you can easily integrate it into your system.
The couple Raspberry Pi 3 B+ and DAC ST 4000, integrated in a box Aluminum and Plexiglas designed in our workshops will prove more particularly resistant and durable.
Connectors
Raspberry Pi inputs4x USB-A
1x Ethernet RJ45
1x Micro SD
DAC ST4000 Outputs1x Stereo RCA
1x HDMI
1x Mini Toslink Optical
SNR127dB
THD+N120dB
Output level2V RMS
ClockUltra Low Jitter TCXO
HDMI32bit 384kHz
Audio formats supportedLPCM 2 Ch
Dolby Digital 2 to 5.1 Ch
DTS 2 to 5.1 Ch
Dimensions102 x 169 x 58mm
CaseAluminium and Plexiglas
Weight610g
Power supply connectorJack DC 5.5 / 2.1mm
AccessoriesPower adapter 5V 2A
InputMicro SD
InputRJ45
OutputUSB
OutputI2S LVDS via HDMI
DAC / ADC ChipES9018K2M
Max sampling rate384kHz
