This version of the Audiophonics RaspDAC LTE is based on a Raspberry Pi 3 and a DAC I-TDA1387. It will allow you to easily access your high definition dematerialized audio files.
By buying this product you get 22 loyalty points
DAC network player Audiophonics I-Sabre V4 ES9023 TCXO and Raspberry Pi 3 B+
Go to the high definition dematerialized with the RaspDac LTE. Housing 100% Aluminum, DAC ES9023 24bit / 192Khz TCXO, Raspberry 3 B+ !
Here is the first affordable solution of dematerialized reading assembled and tested in our workshops.
Ready-to-use network reader electronically, you just have to choose the software solution of your choice (Max2Play, OSMC, piCorePlayer ...).
Simply get a high-end digital audio player with a 24bit / 192kHz Bit-Perfect resolution.
Optimized for the sole purpose of offering maximum music, Audiophonics integrates the new DAC I-Sabre v4 ES9023 24 / 192Khz equipped with a TCXO precision clock as well as a revised and corrected mass circuit, a new low noise regulation LDO capacitors OS Con the DAC I-Sabre v4 is the heart of the RaspDAC LTE.
In addition, its advanced ATX-type power management with different possible shutdown modes offers a high level of ease of use.
This V2 model now has two offsets: one for the HDMI and one for the micro SD card. This allows the RaspDAC LTE to offer even more integration possibilities in any audio system.
It has been designed with the aim of allowing you to have the effectiveness of your Raspberry Pi 3 B+ in a high quality Audio environment. Especially elegant and discreet, it offers you the possibility to have a high-performance audio solution and achieved excellent value for money.
Raspberry Pi 3 | Model B+ |
DAC | Audiophonics I-Sabre v4 ES9023 TCXO |
inputs | 1 x RJ45 / 4x USB-A / 1x Micro SD |
Exits | 1x RCA Stereo / 1x HDMI |
Food | Jack DC 5.5 / 2.1mm |
Dimensions | 102 x 169 x 58mm |
Weight | 0.65kg |
Housing material | 100% Aluminum |
Color | Black |
This 100% Aluminum case designed in our workshops receives the Raspberry Pi 3 B+ & DAC Audiophonics I-Sabre v4 ES9023 TCXO or DAC I-TDA1387 TCXO.
Supplied accessories:
To enable you to be directly operational, the player comes with an 8GB SDHC card. Supplied with an external standard 7V 2A power supply on 5.5 / 2.1 connector.
Input | USB |
Input | RJ45 |
Output | RCA |
Output | USB |
Output | I2S LVDS via HDMI |
Max sampling rate | 192kHz |
Color | Black |
